Author Topic: Glove box door hinge  (Read 25854 times)
« on: September 03, 2004, 16:32:58 »
Does the hinge go above the box or beneath?
Re: Glove box door hinge
« Reply #1 on: September 03, 2004, 16:57:37 »
Not sure what you mean, but here's a photo:
Download Attachment: gbox.JPG
79.29 KB
« Reply #2 on: September 03, 2004, 17:30:11 »
Does the hinge mount right under the bottom flat piece that is secured by screws or is it mounted under the metal glove box?
« Reply #3 on: September 03, 2004, 17:44:01 »
Under the metal glove box.
Then a pad covers the screws.
« Reply #4 on: September 03, 2004, 17:55:39 »
Thanks Naj.
« Reply #5 on: September 03, 2004, 20:41:54 »
Don't forget the spring or you'll have to to lock it just to keep it closed.
« Reply #6 on: September 04, 2004, 06:40:51 »
Sorry Jeff,
Wrong info. :evil:
Hinge goes ABOVE glove box base. On RHD cars, the right end of the hinge has a raised section that the flex wire for the lamp in the door passes under!!
The hinge/box are held on the dash by 4 screws but there are 6 holes. The two smaller holes take rivets which hold the glove box and door together so that the spring/holders can be installed prior to fitting the assembly into the dash board.
Sorry, no picture at present.
« Reply #7 on: September 04, 2004, 07:38:16 »
Thanks Naj.
I'll install it correctly today.
ChrisInNashville
  • USA, TN, Nashville
« Reply #8 on: September 26, 2004, 06:13:03 »
Quick question on an issue related to the spring.    I found my hinge last night loose behind the dash but can't figure out how to reattach.   It consists of the spring with the two "wrench like" inserts that fit the mechanism well, but they don't stay attached.   Am I missing something else?
I appreciate any help or ideas.
I'm a new 'poster' here with a newly acquired '69 280SL
Chris Tietz
Newburgh, Indiana.
‘69 280 SL
‘24 GLE450e
Tennessee, USA
« Reply #9 on: September 26, 2004, 08:24:38 »
Welcome Chris,
The wrenches need to be inserted side by side in each end of the spring.  There is a slotted protrusion on the side of the glove box and another on the glove box door.  The wrench ends are inserted into the slots and the spring remains straight.  The spring does not bend in the middle. Spring tension with the wrenches pushed outward by the spring keep the glove box door open and closed.
« Reply #10 on: September 26, 2004, 20:30:00 »
Be sure that the spring is in good condition. It should not be bent or extended. When I first pulled my glove box apart, I saw that the spring was mis-shaped and did not lie flat. It is critical that the spring be not deformed, twisted or bent. I found a replacement at the local auto parts store. It works like a charm.
« Reply #11 on: September 28, 2004, 13:53:57 »
Take the two "wrench" handles and put each of them into the holes/circles formed at either end of the spring so that the handles are inside the spring pointed towards one another like so.... ]-/////-[
Now squeeze them together by pushing on the wrench heads, compressing the spring until the handles overlap inside the body of the spring.  Now with the glovebox closed, insert the wrench ends ] into the slots in the hinge arms. The wrench handles should stay overlapped and the spring should stay compressed with the glovebox closed. Done correctly, there should be enough tension on the gloveboxe hinge to make it difficult to open when the glovebox is not attached to the car. If you are bending the spring or the wrench handles do not overlap you are doing something wrong.
Mikey
TA250SL
« Reply #12 on: September 28, 2004, 20:52:46 »
You can view a photo of the spring assembly and glove box door at the SL-Tech website, www.SLTech113.com.  Look under parts inventory.
« Reply #13 on: September 28, 2004, 21:05:31 »
« Reply #14 on: September 29, 2004, 05:16:13 »
Here a couple of pics to look at
Download Attachment: GloveBoxForkSpringKit.JPG
32.88 KB
Download Attachment: GloveboxSpringInstalled.jpg
12.59 KB
Bob (Brisbane,Australia)
ChrisInNashville
« Reply #15 on: October 10, 2004, 19:37:08 »
Thanks.   Ya'll are awesome!   I've been down due to computer problems, but now that I'm back, you've helped immensely!
In this process, I've noted that there are no screws holding the glove box in place.   Does anyone know what size/type screws to use?   I'm also going to have to find screw holes since apparently they were covered in the recent reupholstery project.
Any ideas/thoughts are greatly appreciated.
Chris Tietz
Newburgh, Indiana, USA
‘69 280 SL
‘24 GLE450e
Tennessee, USA
ChrisInNashville
« Reply #16 on: October 10, 2004, 19:40:27 »
Chris Tietz
‘69 280 SL
‘24 GLE450e
Tennessee, USA
ChrisInNashville
« Reply #17 on: October 12, 2004, 20:06:57 »
My hinge is on the bottom.   The screws - I think - belong on the top.Any ideas?
‘69 280 SL
‘24 GLE450e
Tennessee, USA
« Reply #18 on: October 12, 2004, 20:53:25 »
My glove box is held in place by two screws on the top and four on the bottom. They are chromed and sit in thin (what looks like) aluminum cups through the MB-tex material.
« Last Edit: October 13, 2004, 13:08:56 by cees klumper »
« Reply #19 on: February 13, 2007, 14:32:25 »
Hello. I am resurrecting this one because I have questions about various dash screws.
Are the below-mentioned cups used in the upper screws of the glovebox as well? And what about the two black plugs in Douglas's picture? Are these correct? and available? anybody have a handful of cup washers???
« Last Edit: February 13, 2007, 15:11:05 by J. Huber »
Roman Kishi
  • USA, VA, Fairfax
« Reply #20 on: February 13, 2007, 21:39:37 »
Actually, I looked for these cup washers before. Are they available anywhere?
Roman
Northern Virginia
280 1969,Signal Red, Auto
Roman
Northern Virginia
« Reply #21 on: February 14, 2007, 10:39:24 »
I think the cup washers are called finish washers.  Available at good hardware stores that have a decent selection of fasteners (screws, nuts, bolts, etc.).
« Reply #22 on: February 14, 2007, 12:19:49 »
Thanks George. I did try a few of our local places and even bought some of the "finish washers". But the only ones they had are more rounded and the screw sits up high. The Pagoda washer seems to be more recessed, letting screw be almost flush with the vinyl. But I will keep looking...
« Reply #23 on: February 14, 2007, 13:35:13 »
Good hardware stores are hard to find, actually.  Try your local aircraft maintenance supply store, or maybe these guys:
http://www.wicksaircraft.com/catalog/product_search_results.php/search=bmFzMzkw
« Reply #24 on: February 14, 2007, 14:26:55 »
Thanks GD. I'll have a look around. I guess I am just searching for some simple, fairly easy improvements to do this winter -- and my screws throughout the car are fairly mish-mashy. It would be nice to have a database here of just screws...part numbers & pictures or some such thing.
