Author Topic: Threaded stud on taillight bezel  (Read 5981 times)
280sl1968
« on: May 25, 2013, 06:39:27 »
I've found that my chrome taillight surrounds is missing one of these. Can they be obtained separately and are they threaded both ends (ie. do they just screw into the frame?)
The light assembly is the '68 and earlier type.
David
w113dude
Re: Threaded stud on taillight bezel
« Reply #1 on: May 25, 2013, 13:58:45 »
find a long screw from your local hardware store with the same thread and cut the tip off with a hacksaw.
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #2 on: May 25, 2013, 18:07:36 »
According to the measurements I made when I put mine in the batch to be CAD plated, there are six that are M5 x 0.8 mm thread x 64 mm long and two that are M5 x 0.8 mm thread x 54 mm long.  The slightly shorter ones are located at the outside lower corners of the housings.
M5 x 0.8 mm thread is a normal metric thread, but 64 mm and even 54 mm long screws of that small size might be hard to find.  The studs are a Part In Assembly of the tail lamp frame so they are not even listed in the EPC.  Finding screws and cutting off the head is probably the best idea.  If that doesn`t work, try searching for a 5 mm threaded rod and cut to length.  Good Luck
Tom Kizer
« Reply #3 on: May 29, 2013, 19:48:23 »
Here is where I would go. I buy a lot of stuff for my car there. They take credit cards also.
http://www.mcmaster.com/#standard-threaded-rods/=mypuo4
Go to metric and medium strength 8.8. These aren't cad plated but zinc is a good substitue.
280sl1968
« Reply #4 on: May 29, 2013, 23:23:46 »
I have ordered a length of M5 rod to cut down to size. Will let you know how it works out.
Thanks everyone.
David
280sl1968
« Reply #5 on: June 14, 2013, 17:13:56 »
Just to close this one off, the suggestion of cutting down M5 threaded rod to size was a good one.
The only problem was that (on mine anyway) where the existing studs go into the frame, they are threadless/smooth, whereas I thought I could simply screw in the new piece of rod, there is no corresponding thread in the frame. They must have been brazed in somehow originally.
Anyway, it was a snug fit, and a little bit of metal epoxy putty did the trick and has held the new stud firmly in place.
Thanks for everyone's help on this one.
David
« Reply #6 on: June 14, 2013, 19:57:15 »
The threads were probably stripped in the frame I would imagine. Threads in pot metal aren't strong and are very brittle. If the studs are overtightened initially or corroded when removed, the threads will dissapear in a flash. I am not sure pot metal can tolerate the temperature of brazing, maybe soldering. But you had a good solution to the problem and should last.
I just glued my all red lenses to the newly chromed frames and am going to install new studs. Because you cut the studs to the correct length, you need to make sure you clean the cut end with a die or you can ruin the threads in the frame or the attaching nut. Depending on how tight the stud is in the frame, I might use a very mild Loctite thread locker.
