Author Topic: Back Seat Configurations?  (Read 5857 times)
250SLFranco
« on: May 16, 2013, 19:02:42 »
I own a 1967 250SL importated from Germany in 1967 and I have no back seat.  I recently met another 250SL owner and he had a jump seat for the back seat.  How many configurations for back seats were made and could my back seat be modified to have a jump seat?
Thanks For The Help.
Re: Back Seat Configurations?
« Reply #1 on: May 16, 2013, 19:45:41 »
Franco,
I think there were three configurations.
Most common is just a shelf area; this is in standard cars with the soft top.
Then there is a "kinder seat" option, which is a sideways seat (back on the right side of the space) which is sometimes fitted to this standard area.
Finally there is the California Coupe; w/o a soft top compartment, this space is a bit larger.  I've seen upholstered bench seat of sorts (not a whole lot of leg room even for a child) in that space
Any other, I'm not sure about...
250SLFranco
« Reply #2 on: May 16, 2013, 20:26:26 »
Thanks mdsalemi!
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #3 on: May 19, 2013, 15:35:59 »
Foranco,
I have a Euro spec with Kinder Seat (you refer to it as jump seat).  Yes you can fir this seat to your 250SL.  Problem would be to find one.  The right half of rear deck comes out, and seat fits in it's place.  The left half of deck (behind the drivers seat) comes out to evpost the leg room floor.  There is a small wooden piece that fits on floor to make it flat for feet.  Then you must carpet this area.
Robert Hyatt
Williamsburg, VA.
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #4 on: May 19, 2013, 19:46:10 »
The kinder seats are quite often on eBay but usually rediculously expensive.  In fact, there are three right now on eBay.
If I needed one (Mine came with one), I would take the multiple photos on eBay with the insides exposed due to decomposition and make my own by asking someone like me to measure the two pieces of plywood that are used as bases for the seat and back.  You can buy hardware to attach it to the car from Authentic Classics.  I suspect you could make a set (seat and back) for a hundred dollars or two worth of material, not counting the leather required to upholster it.  You would also need carpet for the footwell on the other side.
There`s also a jumpseat set on eBay (It comes up if you search kinder seat).  It`s only about $700 but is tan leather and depending on your color would need to be completely reupholstered.
Anything is possible with lots of money or a little money and lots of talent and skill.  Good Luck.
Tom Kizer
