Author Topic: Trim molding removal  (Read 5912 times)
230slhouston
  • USA, TX, Houston
« on: March 09, 2013, 03:40:17 »
I am removing my trim molding below the doors etc. the screws are rusted. I tried drilling these out they seem to really hardened, broke two drill bits. Any idea how to remove them, special bit?
I am attaching a picture.
IXLR8
Re: Trim molding removal
« Reply #1 on: March 09, 2013, 04:24:07 »
Hi --
You may look into removing the interior door panel and getting at the screws from the back side. You might want to soak them in WD40 and then try twisting them with a vise-grip type locking plier.
the other Joe
« Reply #2 on: March 09, 2013, 05:10:09 »
I had some success in similar situations using a mini impact driver (cheap at Harborfreight) after soaking the screws for several days with PB-Blaster. But make sure you hit the screw head straight on and not at an angle and clean the slot as much as possible to seat the tip.
Once the Philips cross gets round you can then cut a slot with a small Dremel wheel and try again.
Larry & Norma
« Reply #3 on: March 09, 2013, 10:17:18 »
I used the Dremel method successfuly also.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
230slhouston
  • USA, TX, Houston
« Reply #4 on: March 09, 2013, 22:05:04 »
Thanks folks. I used the combination of methods recommended and took out the trim. Took longer then i thought.
IXLR8
« Reply #5 on: March 10, 2013, 02:08:16 »
Everything I do on this car takes more time than I thought it would! LOL
I'm sure it's my abilities relative to the car's needs.
the other Joe
w113dude
« Reply #6 on: March 10, 2013, 13:51:29 »
Yes, but think of how much easier it would be on your second Pagoda project. :)
tel76
« Reply #7 on: March 10, 2013, 14:13:12 »
I can assure you it does not get easier
Eric
