Author Topic: correct battery?  (Read 7150 times)
gnj588d
correct battery?
« on: July 08, 2011, 20:43:47 »
Does anyone know the correct battery for my 66 230 and where I can get one in the UK.Cheers .Mike.
merrill
Re: correct battery?
« Reply #1 on: July 09, 2011, 00:34:53 »
I got an OEM from MB (dry)
There are others that will fit
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #2 on: July 09, 2011, 06:17:02 »
Correct battery is anything that will fit with the posts at the back and is 12 volt. This narrows it down quite a bit as there are lots that won't fit at all.
 I also use the MB battery - they're far too exspensive but some people want that star on them. Probably made by Varta.
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #3 on: July 09, 2011, 17:22:10 »
I believe the Optima is a 34R.
« Reply #4 on: July 09, 2011, 21:19:25 »
Here's one from a well known car...
Naj
gnj588d
« Reply #5 on: July 10, 2011, 21:22:01 »
Thanks to all should get sorted this week.Regards Mike.
IXLR8
« Reply #6 on: July 10, 2011, 22:50:52 »
Hi Dan--
Your post indicated any 12V that will fit with the posts at the rear.
How many cold crank amps (CCA) should we look for?  For example, my R107 is 750 CCA.
Joe
