Become a
Full Member
Emergency Contact List
Electrical and Instruments
correct battery?
Topic: correct battery? (Read 7148 times)
gnj588d
correct battery?
July 08, 2011, 20:43:47 »
Does anyone know the correct battery for my 66 230 and where I can get one in the UK.Cheers .Mike.
merrill
Full Member
Platinum
USA, TX, Austin
Re: correct battery?
July 09, 2011, 00:34:53 »
I got an OEM from MB (dry)
There are others that will fit
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
July 09, 2011, 06:17:02 »
Correct battery is anything that will fit with the posts at the back and is 12 volt. This narrows it down quite a bit as there are lots that won't fit at all.
I also use the MB battery - they're far too exspensive but some people want that star on them. Probably made by Varta.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Raymond
Full Member
Platinum
USA, FL, Jacksonville
Reply #3 on:
July 09, 2011, 17:22:10 »
I believe the Optima is a 34R.
Associate Member
Platinum
United Kingdom, Surrey, New Malden
Reply #4 on:
July 09, 2011, 21:19:25 »
Here's one from a well known car...
Naj
gnj588d
Reply #5 on:
July 10, 2011, 21:22:01 »
Thanks to all should get sorted this week.Regards Mike.
IXLR8
Reply #6 on:
July 10, 2011, 22:50:52 »
Hi Dan--
Your post indicated any 12V that will fit with the posts at the rear.
How many cold crank amps (CCA) should we look for? For example, my R107 is 750 CCA.
Joe
correct battery?
