with our official
Pagoda SL Group logo
from our official partner.
Electrical and Instruments
Heater Motor Knob
Topic: Heater Motor Knob (Read 6568 times)
Full Member
Platinum
Heater Motor Knob
April 17, 2010, 13:37:56 »
Should it have a light in it or not? Can't seem to a) find anything definitive on here on this and b) see anything on a repair (should there be a need for one)
Associate Member
Platinum
USA, WI, Mequon
Re: Heater Motor Knob
April 17, 2010, 14:19:46 »
Mine does, very small.
Reply #2 on:
April 17, 2010, 14:50:33 »
230 sl and 250sl made up to the /8 change over had a light in the blower switch. After changing to the larger diameter knob there was no longer a light bulb. The 280 switch still has a hole in the housing where the bulb was previously mounted, but none of the internal wiring.
photo left - non lighted 280sl switch, the knob is from a radio to show size and style. I think the 280 fan knob had a blue arrow
photo right - lighted fan switch from 230sl with clear plastic tip that extended through a hole in center of knob. This switch was also used in fin tail sedans and coupes.
Full Member
Platinum
Reply #3 on:
April 17, 2010, 17:17:07 »
Thanks for that
Explains volumes: 280 with the blue arrow on mine
Pagoda SL Board
Platinum
USA, CA, San Marcos
Reply #4 on:
April 18, 2010, 00:33:29 »
Al, also, the ones that do have the light bulb, it only comes on when the switch is in the on position, not necessarily when the light switch is turned on? Correct?
Reply #5 on:
April 18, 2010, 02:49:01 »
Yes. The light in the heat fan switch is NOT connected to the dash illumination circuit. As you said it only comes on as an indicator that the fan is switched on.
knockmacool
Reply #6 on:
April 18, 2010, 07:31:57 »
Does anyone know why the earlier knob is not completely round?
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Reply #7 on:
April 18, 2010, 07:45:39 »
I think the flat spot was suppose to be in a certain position when off. Left or down... I don't remember off hand.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
Associate Member
Platinum
USA, WI, Mequon
Reply #8 on:
April 18, 2010, 14:08:23 »
My light is always on...but, that's because my fan is always on (low speed). I keep it running so that it, well, keeps running!
Heater Motor Knob
