Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
location of Plug Connection Tail Light Leads (46)
Topic: location of Plug Connection Tail Light Leads (46) (Read 5504 times)
Iconic
Full Member
Platinum
USA, IL, Highland Park
ex-Membership Administrator
March 05, 2009, 04:25:26 »
For a 280 SL, can anyone tell me the location of the "Plug Connection Tail Light Leads" (#46) as shown on the wiring diagram?
It's too cold in my garage to snoop around for it. Mine is an early model year '70, if that matters.
Thank you,
Mark
1968 SS396 Camaro Convertible (owned since 1977 -- my first car
1998 BMW M-Rdstr Estoril Blue
Anfinn
Re: location of Plug Connection Tail Light Leads (46)
March 05, 2009, 08:16:45 »
I think the connector is located on the inside of the panel behind the driver seat. - the carpeted panel that has the handle for opening the soft top cover.
Reply #2 on:
March 10, 2009, 01:08:56 »
The tail light harness breaks out of the main dash board harness at plug #46. This plug is located above the left kick pannel in front of the door. the harness goes from the plug then down under the chrome door sill moulding then through a frame rail under the top boot then into the trunk. Plug 46 is the only connection for this harness that is outside of the trunk.
Iconic
Full Member
Platinum
Reply #3 on:
March 10, 2009, 02:24:52 »
Boy, I thought I was going crazy there until I read the posts about the lost posts !!!
My lost post simply thanked Al for his description and picture.
Thanks again.
Mark
Reply #4 on:
March 10, 2009, 09:45:43 »
Does anyone know why MB installed the small string around the base of the front wire harness connector?
My w113 is a '71 and also has this string around the base.
georgem
Full Member
Gold
Australia, Queensland, Birkdale
Reply #5 on:
March 10, 2009, 23:09:36 »
My guess would be its a mouse - what you see is one end of the string. The other runs through the tunnell/ box section where the loom runs. Uncle Merc left it there in case other wires had to be run later. ie find the other end of the bit of string (where you want the wire to end up), untie the entry end, tie it to your new wire and away you go. Dont forget to tie a new bit of sting to it so you can pull it back for use next time.
Either that or Hans on the assemble line was a bit of a practical joker so he tied it there so someone in 45 years time would wonder what it was for.
Cheers
George
230SL
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
