» Wanted To Buy
View full version:
Wanted To Buy
19
Exhaust system for 1971 280SL
(WTB) 280 SL Soft-top Full assembly w/ canvas
Temperature Gauge for Dashboard 1969 280SL
!969 280 rear view mirror as close to perfect or NOS
ZF S5-20 5 speed Transmission wanted
Rear Driver Side Brake Caliper Part number 19-266
Passaenger-side Front Inner Wheel House Thin Panel that Connects House to Fender
Left side quarter panel trim
230SL Left front Disc Backing Plate
Right side lower window guide w113
"Short" Fuel Pump Electric Insulator/Studs
Seeking 14x6 Aluminum Wheels
Brake servo/Booster vacuum line connection
Gearbox case cover
230 SL early exposed-screw jack.
Boot/trunk panels..
Gas Cap
Fuel Pump for '68 280SL
WTB: Carpeting Remnant - "Wheat"
3.27 rear end
0015459224
1970 280SL turn signal wiper arm
Nose panel patch
W113 used wiring harness
6 pin connector plugs
WTB Fuel injector line 3 notch bracket
Silver metal dash ‘Escutcheon’ pieces behind HVAC levers for RHD
Pagoda World
Automatic kickdown switch housing
Need a spare tire cover
Complete Rebuild Kit for W108/W110/W111/W113 Axle
Metal Frame For Soft Door Map Pockets
Interior windshield gasket
WTB Dashboard ashtray for W108
Fuel injector cleaner and spray pattern tester
Exhaust Heat Shields full set ho many?
WTB Front Jacking Point Plug for W108
WTB ashtray for 1967 230SL
air filter canister and left motor mount arm
Seeking 250SL/SE Cylinder Head
230sl 1967 radiator for automatic needed
RH Sun Visor - 230SL
Heater matrix sl230 1964
1965 230sl Hard Top Needed
Complete Wiring Loom
door lock escutcheon scew cover
Mercedes horn button for Nardi steering wheel
Seat back grilles for 250 SL
parts wanted heater blower housing
Wanted 1961 220Sb speedometer cable FOUND ONE
