Author Topic: diagram for solenoid  (Read 6266 times)
3523pleigh
« on: December 01, 2008, 16:42:02 »
I need the electrical diagram for the solenoid on the 230 transmission. Can anyone can help with this. The transmission was completely rebuilt by a train mechanic. It did shift rough afterwards. I had a modulator valve installed. Now the transmission slips and up shifts and down shifts erratically. Any ideas?  Phil
« Last Edit: December 02, 2008, 11:05:05 by 280SL71 »
merrill
Re: diagram for solinoid
« Reply #1 on: December 02, 2008, 01:43:12 »
Phil
see this link.
Maybe you will find some helpful info
http://www.mercedesdismantlers.com/16BoltInstallationInstructions.html
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
graphic66
Re: diagram for solenoid
« Reply #2 on: December 02, 2008, 13:40:51 »
The only thing missing at the http://www.mercedesdismantlers.com/16BoltInstallationInstructions.html site is the positive + feed for the idling switch on the throttle body bringing power from fuse # 3. Other than that it is complete and accurate.
« Reply #3 on: December 03, 2008, 02:23:25 »
Phil,
here is a wiring diagram
Pressure switches #7 and #8 activate the constant speed solenoid #6 when the transmission is placed in forward or reverse.  Later version W113s with automatic transmissions  and AC had no pressure switches. The same constant speed solenoid was used but was activated when the  AC was switched on.
« Last Edit: December 03, 2008, 02:35:01 by ja17 »
69280sl
  • USA, IL, Elk Grove
« Reply #4 on: December 03, 2008, 02:58:46 »
Joe: Dumb question. On later auto 113's does the CSS not engage when the car is put into gear? Only if A/C is switched on?
Gus
perry113
  • USA, NY, Rensselaer
« Reply #5 on: December 04, 2008, 02:47:54 »
Just out of curiousity, is your fuel injection linkage set up properly. As I have just found out improper linkage adjustments can cause havoc on proper transmission shift operation.
Peter Perry
1969 911T Tangerine
abe280SL
« Reply #6 on: December 06, 2008, 05:06:30 »
Gus, I have a 280sl without a/c and the css engages in drive or reverse. It does so by completing ground in one of two pressure switches located on either side of the transmission.
abe
« Last Edit: December 06, 2008, 05:11:05 by abe280SL »
