Author Topic: Rim color  (Read 6021 times)
Joe
  • USA, CO, Colorado Springs
Rim color
« on: September 08, 2008, 18:22:07 »
I can't find this topic using the Search function. What color should the wheel rims be?
Joe
« Last Edit: September 09, 2008, 04:14:59 by 280SL71 »
  • USA, WI, Mequon
Re: Rim color
« Reply #1 on: September 08, 2008, 18:36:09 »
I've seen variation, but the most common seems to be the color of the hardtop (rims and hubcaps).
Re: Rim color
« Reply #2 on: September 08, 2008, 19:01:22 »
For later cars ie full hubcaps the wheels are black.
Re: Rim color
« Reply #3 on: September 08, 2008, 19:24:25 »
I understood the rims were the same colour as the body and the hub caps were the same colour as the hardtop.
benzportland
Re: Rim color
« Reply #4 on: September 15, 2008, 23:33:51 »
My sig red 230sl has rims which match the hardtop, papyrus white.
Re: Rim color
« Reply #5 on: September 16, 2008, 01:08:45 »
Far clarity's sake, when you are asking about "rims" you are asking about the wheel rims on which the tires are mounted and not the hub caps, correct?
My 230SL wheel rims are painted body color (Havana Brown 408) and my hub caps are painted to match the hard top (Light Beige 181).
Download Attachment: Detail.jpg
85.21 KB
Klaus
Re: Rim color
« Reply #6 on: September 16, 2008, 08:30:03 »
" I can't find this topic using the Search function."
The search function obviously does not look into our Technical Manual, see:
http://www.sl113.org/wiki/pmwiki.php?n=WheelsTires.Rims
Scroll down to color
glcg123
Re: Rim color
« Reply #7 on: September 16, 2008, 19:02:54 »
The outside of the rims usually match the car colour. In my case the wheels on my 230SL are papyrus white. However, the inside of the rims are a silver colour, based upon my spare which was mounted with the original tire. The inside of the rims on the car are also this colour but hard to see due to brake dust and dirt.
George 1965 230SL
