Author Topic: glove box light wires  (Read 3815 times)
rmmchl
  • USA, WV, Charleston
« on: August 03, 2008, 11:31:37 »
2 wires from the glovebox light screw into the side of the vent box(black plastic box) 2 connect on one terminal and 2 wires screw into the other terminal. I have the box removed for heater core work and forgot how they go back-------do the 2 wires from the glove box conect to the same terminal?-does anyone have a picture?
michael romeo
1967  250sl
signal red
Re: glove box light wires
« Reply #1 on: August 03, 2008, 12:07:30 »
Have you tried the search function?
It would find you this, for example: http://www.sl113.com/forums/index.php?topic=9109
« Last Edit: November 14, 2008, 16:56:50 by vanesp »
rmmchl
« Reply #2 on: August 03, 2008, 13:05:17 »
thanks you 66 blue----------looks like both wires connect to one screw and the 2 from the clock connect to the other-ps-I removed my heater core-I will take it to the shop to rebuild and remove the valve I dropped in it. Also one bracket came off of heater core-I guess they can solder it back on-I dont know how it was connected-the core is retained by 4 screws that bolt from both sides with a bolt and nut. Also, the lid was loose again. Years ago , I tried to jb weld it. It held for a few years. I.m going to leave it off this time. Would you know where to get the replacement foam that was glued on the core?
michael romeo
1967  250sl
signal red
