Author Topic: Name this part? (ongoing thread)  (Read 5968 times)
awolff280sl
  • USA, FL, Sarasota
« on: August 01, 2008, 07:27:04 »
Posting this is probably a shot in the dark. The part is pretty much non-descript, just some sort of bracket. A little unnerving.
I found it lying on the garage floor under the left front part of the engine bay after working on new brake lines off the master cylinder.
Looks a little like the hood strap bracket, but that's not it.
« Last Edit: August 19, 2008, 12:13:36 by AWOLFF280SL »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Re: Name this part? (ongoing thread)
« Reply #1 on: August 01, 2008, 07:32:24 »
I think its the bit that holds the check-strap to the hood (as in bonnet  :) )
dtuttle123
« Reply #2 on: August 01, 2008, 07:56:56 »
It does look like the strap bracket - probably from the previous owner who lost it down the engine compartment, and it's just now finding it's way out to sunshine!
Doug
« Reply #3 on: August 01, 2008, 08:35:52 »
I concur!  Neat that it survived with fasteners intact!
  • USA, WI, Mequon
« Reply #4 on: August 01, 2008, 08:42:09 »
« Last Edit: August 01, 2008, 08:42:50 by thelews »
« Reply #5 on: August 01, 2008, 09:21:11 »
It definitely looks like the hood strap bracket.  When I removed my hood hinges (for car repaint), I found one of these hood strap plates being used as a shim under the fender-side hinge (you never know: you might have an extra one).
awolff280sl
  • USA, FL, Sarasota
« Reply #6 on: August 19, 2008, 12:26:32 »
This is a rubber piece found next to the upper end of each front end spring. It's kind of "spout-like". Maybe some sort of drain channel?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #7 on: August 19, 2008, 12:48:14 »
Nope. This is the underside of the rubber bumpers which prevent the upper A-arm from slamming into the subframe when the suspension is fully extended.
