Author Topic: front chrome grille removal  (Read 4727 times)
loizou
« on: July 13, 2008, 09:15:01 »
does anybody know how to remove the front grille safely in order to allow access for hood alignment 8)
Re: front chrome grille removal
« Reply #1 on: July 13, 2008, 09:36:12 »
If you look through the grille, you'll see 4 screws at the top, and 4 at the bottom. Remove these and carefully slide out the grille forward. You'll probably see some remnants of white paper tape under the grille edges-- this is original (they installed it this way in order to prevent paint scratches).
Next, you'll need to remove the inner grille guards (black louvres). These are affixed using impossible-to-access screws on the top and bottom edges. You'll need a screw driver with a very very very short handle and little baby hands to do this. I'm sure others here can help with better instructions.
« Last Edit: July 13, 2008, 09:38:02 by waqas »
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #2 on: July 19, 2008, 07:11:58 »
You'll need:
A right angle screwdriver allowing about a quarter turn at a time.
Lots of patience.
Some luck.
And, possbily a small band-aid.
« Reply #3 on: July 19, 2008, 12:45:13 »
My guess is.. more than the one band-aid
