Author Topic: ground wires to instruments  (Read 7392 times)
Joe
  • USA, CO, Colorado Springs
« on: July 09, 2008, 12:58:24 »
I'm sorting through the dash of a 230SL I bought last year, and am wondering if there are separate ground wires to the tach, speedo, clock and center gages. The previous owner sort of put things together the way he wanted, with no knowledge of what is right.
Joe
Re: ground wires to instruments
« Reply #1 on: July 09, 2008, 13:23:31 »
There are definitely separate ground wires to each of the speedo and tach, but not sure about the center cluster (I think that ground is part of the harness that attaches behind the center cluster).
The ground cables attach via the knurled nut that tightens the rear holding clamp on each instrument.
graphic66
« Reply #2 on: July 09, 2008, 17:02:33 »
And they are brown.
Joe
« Reply #3 on: July 10, 2008, 10:17:54 »
Thanks, guys. Does the clock also have a ground wire?
Joe
egggplant
« Reply #4 on: July 10, 2008, 11:49:44 »
This is a common grounding method that I've seen on many cars of the period such as Volvo, Alfa Romeo, etc.
« Reply #5 on: July 10, 2008, 12:52:31 »
Joe
If I remember correctly, the clock has a little wiring harness connector that should contain the ground wire as well.
« Reply #6 on: July 14, 2008, 21:53:40 »
 Only the tach (rpm gauge) and the speedometer have the separate brown ground wire with the ring terminal which attaches under the knurled thumb screw. The center gauge and the clock are grounded through their wiring harness and plug arrangement.
