Author Topic: doorhandle rechrome  (Read 4745 times)
pablo_o2
  • Belgium, Flanders, Zoersel
doorhandle rechrome
« on: June 21, 2008, 10:45:01 »
As I want to rechrome the doorhandles I have to remove the cylinders inside. Is there a special way or trick to do so because at first sight I don't see how it's done.
« Last Edit: June 21, 2008, 17:02:24 by 280SL71 »
anthrope
Re: doorhandle rechrome
« Reply #1 on: June 23, 2008, 05:37:43 »
A point to consider here. Your doorhandles are probably quite worn by this point, so you might be better off ordering a brand new set from Mercedes, who will make you one based on your car's VIN. The cylinder on my driver's side door broke off, so I ordered one from Mercedes. I was quite pleased that my 40 year old key was able to open the new doorhandle!
Prashanth
pauldridge
« Reply #2 on: June 27, 2008, 07:46:05 »
I did the same with mine... still disassembled awaiting painting.  I don't recall any unusual problem in removing them.  Seems like there was a pin that holds the whole mechanism in the handle that is driven through to remove, but it's been awhile.  Look carefully along the barrel of the lock.
