Author Topic: Distributor  (Read 5949 times)
wgl0
Distributor
« on: March 26, 2008, 21:46:29 »
Does anyone know where I can look at a complete assembly schematic and parts description for a Bosch 0231116 051 distributor? This would be the black iron distributor that was used on early 68 280 SL's or late 250's.
Thank you.
Bill Lindquist
280 SL Signal Red
« Last Edit: March 27, 2008, 07:30:31 by 280SL71 »
Re: Distributor
« Reply #1 on: March 27, 2008, 07:24:07 »
Bill,
If the word "DISTRIBUTOR" is on your mind, particularly one that may not work or is questionable (why else would you need a schematic) I'm going to offer my sage advice before HE does...HE being Dan Caron, Dr. Benz.
There's so many little things going on inside these units that even a schematic won't substitute for years of experience and testing that only a proper tester can provide, and one with the experience.
If you have any issues with your distributor, don't look for a schematic.  Look for a shipping box, and contact Dan Caron--really.
Mercedes-Benz Club of America
jameshoward
Re: Distributor
« Reply #2 on: March 27, 2008, 08:26:57 »
Michael,
I take your point and agree that Dan's the Man when it comes to dizzy's, however with his advice I took mine completely apart and replaced everything except the sets of metal bushes and it's like new. Dan will probably say that one needs a special machine to test the dizzy advances/retards (051) properly and I have not had this test done. However, my dizzy (051) looks and works superbly. A number of the internal components were damaged and replacing them was quite straight forward and rewarding also. Plus I live in Germany and so shipping it to CAN was not really a swift option.
Bill, I don't have a diagram. However, do a search under distributors and in there somewhere you'll find (a) a ton of information, and (b) a link to a website where a guy rebuilds (more cosmetically that mechanical I think it's fair to say) dizzy's for VWs. His site is useful only because it shows in lots of photos what the dizzys are like when taken apart. I have a load of photos of mine I can send if you email off line and aren't in a hurry (I'm travelling now). I'd say have a go at it. I am glad I did. Just note, though, that to get it tested properly you would need to send it to Dan. What I would definately do is call him and get a rebuild kit from him. He's very helpful. Finally, you don't need a diagram. Just a digital camera and the search function here.
JH
James Howard
1966 LHD 230SL
wgl0
Re: Distributor
« Reply #3 on: March 27, 2008, 10:59:01 »
Thanks for the information. I wanted a schematic to see where the fiber washers and the other small pieces go. My issue with this distributor is that I have the same ohm meter reading between the points whether they are open or closed. I am looking at the points installation to see if they should be shielded from ground some way.
I rang up the Bosch website and could not find any reference to what I was looking for.
Bill Lindquist
280 SL
Re: Distributor
« Reply #4 on: March 27, 2008, 11:50:09 »
Originally posted by wgl0
Thank you.
Bill Lindquist
280 SL Signal Red
Search our wiki for distributor. I think there is enough info there for what you need.
