Author Topic: soft top box repair  (Read 7092 times)
paulr
soft top box repair
« on: March 23, 2008, 16:40:52 »
There is damage on my soft top box slots where the frame / hinge has folded down onto it leaving unsightly gouges when the top is nicely folded away . Can this be repaired do we know ?
paulr
lovely 1970 280 SL
Re: soft top box repair
« Reply #1 on: March 25, 2008, 15:56:18 »
PaulR,
This soft top cover is aluminum, thus allowing it to dent easily.
Walter
1967 220SL diesel
paulr
« Reply #2 on: March 25, 2008, 16:01:20 »
...and therefore  making it unrepairable?
PaulR,
Walter
1967 220SL diesel
paulr
1970 280 SL
« Last Edit: March 25, 2008, 16:13:20 by paulr »
« Reply #3 on: March 25, 2008, 17:46:00 »
I'm guessing it's repairable, Paul. In fact, it's good that it's on an isolated panel where touch-up work that isn't a perfect 100% match in color won't be obvious.
It's definitely one of the areas that's prone to damage on a Pagoda from the folding and unfolding of the top. The hardtop also tends to chip up that area.
« Last Edit: March 25, 2008, 17:48:03 by Douglas »
jsaylor
« Reply #4 on: March 25, 2008, 21:12:09 »
Paulr,
I had bad damage to mine on one side and had it repaired by my body/paint guy.  No problem.
Good luck.
Jim Saylor
Kauai, Hawaii
'65 230SL
paulr
« Reply #5 on: March 26, 2008, 02:45:05 »
thanks Jim, I knew you guy's would know.
Originally posted by jsaylor
Paulr,
Good luck.
Jim Saylor
Kauai, Hawaii
'65 230SL
paulr
1970 280 SL
« Reply #6 on: March 26, 2008, 10:10:07 »
My soft-top case has small grooves/scrapes on each side that may or may not be gouges. They are definitely missing some paint though and are unsightly. I have thought about having the case re-sprayed -- but then again there are plenty of other small chips around the car to keep them company.
