Author Topic: Oil Pressure Line  (Read 7350 times)
awolff280sl
  • USA, FL, Sarasota
Oil Pressure Line
« on: March 22, 2008, 06:22:46 »
After replacing the oil pressure line with a new line, is it necessary to somehow get the air out of the line and get a column of oil into it? In other words, do you have to bleed the air out of the line somehow before hooking it back up to the center instrument box?
Andy
Sarasota, FL
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
merrill
Re: Oil Pressure Line
« Reply #1 on: March 22, 2008, 07:59:12 »
Andy
I asked gernold this very question and he said no.
when I re-installed my instrument cluster I just hooked everything up and started the car.
you could, if you wanted to, bleed the system, but why chance the mess.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
mbzse
« Reply #2 on: March 22, 2008, 08:36:59 »
Of course you should do this, anytime you have the central cluster out. :)     .Both in order to bleed out any air, but also to displace the old, stale oil from the line.
Put a small cup to catch the oil, and crank the engine w/o starting until fresh oil comes out. That means, disconnect the ignition before cranking.
/Hans in Sweden
« Last Edit: March 22, 2008, 08:39:41 by mbzse »
/Hans S
awolff280sl
  • USA, FL, Sarasota
« Reply #3 on: March 22, 2008, 08:48:15 »
What's the easiest way to disconnect the ignition? Pull the center cable out of the distributor cap?
Andy
Sarasota, FL
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
France
« Reply #4 on: March 22, 2008, 12:14:05 »
Hi Andy,
So yours must not have been the ivory car I saw at Hoyt's when I picked up Carling with her new soft top?  They used it as a model to reassemble her bits...
Trice
Think of your Pagoda as a woman with a past...stable now including a 92 911 Carrera 2 Tiptronic
Trice
Austrian Alps
« Reply #5 on: March 22, 2008, 15:41:13 »
I think it is a Bourdon tube(the French rangled their way in).  It responds to a gas and/or a fluid equally-I think.
abe280SL
« Reply #6 on: March 22, 2008, 17:24:45 »
IMO I think its easier to disconnect from the coil than the distributor cap....but either one will do.
abe
abe
1968 280SL Auto
Signal Red w Beige Int
awolff280sl
  • USA, FL, Sarasota
« Reply #7 on: March 22, 2008, 21:23:59 »
Trice,
My car is ivory, but I'm the only one playing with its bits... in the privacy of my garage.
Andy
Sarasota, FL
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #8 on: March 22, 2008, 22:51:28 »
Plull the wire from the coil. Ask me how I know this besides zapping myself and starting a fire once......
