Author Topic: Clock  (Read 5232 times)
hightec
Clock
« on: February 22, 2008, 04:20:29 »
VDO clock not working, does any one have any pictures etc, how to take clock apart and what is the cause
Re: Clock
« Reply #1 on: February 22, 2008, 04:54:49 »
Here is an article I found that may help you...
http://www.drivewerks.com/tech/mult_vdo_clock_repair.htm
Mine stopped working a few years ago and it was the soldered fuse connection.  It was broken.  To fix, I simply resoldered with low temp solder, as mentioned in the article above...
I think that these old clocks are pretty solid.  Most people replace them not knowing a simple solder fix, fixes the clock...
Good Luck!
« Last Edit: February 22, 2008, 04:55:04 by bpossel »
Re: Clock
« Reply #2 on: February 22, 2008, 08:00:02 »
here is a thread where I posted close up photos of the clock winding solenoid and where the fusable joint comes apart.
http://index.php?topic=6239
Al Lieffring
66 230SL
philmas
Re: Clock
« Reply #3 on: February 22, 2008, 12:31:02 »
Well, a blown out fuse  might not be the only issue...
I experienced a more complex problem that a jeweller or even an automotive electrician couldn't solve, and decided to send my clock to palo Alto Speedometer.They did a wonderful and drastic job , just converting the mechanism to quartz.Still cheaper than a new clock  (circa €400! at SLS) and more respectful of the original, as the look remains unchanged (don't even mention this  awful "quartz" logo... :D ).
Philippe from Paris
'71 280SL manual 4sp
« Last Edit: February 22, 2008, 12:31:41 by philmas »
Philippe from Paris
Euro '71 280SL manual 4sp
