with our official
Pagoda SL Group logo
from our official partner.
Electrical and Instruments
Fuses Ratings
Topic: Fuses Ratings (Read 9595 times)
230slhouston
Full Member
Senior
USA, TX, Houston
Fuses Ratings
February 03, 2008, 17:38:09 »
Does anyone have the list of fuse amps by fuse number? I need to replace all my fuses.
I am blowing my fuel pump fuse intermittently, id don't have an electrical short, I may have a fuse that is low amps.
MBP
Maistran (MB)
230sl
Full Member
Platinum
USA, CA, Cedar Ridge
Re: Fuses Ratings
February 04, 2008, 21:47:30 »
Hey 230, you can find this info in your manual (if you have one!) If not, or even if, here is the 1-12 in that order according to my manual:
PS left to right
Last Edit: February 04, 2008, 21:48:25 by J. Huber
230slhouston
Full Member
Senior
USA, TX, Houston
Re: Fuses Ratings
Reply #2 on:
February 04, 2008, 22:12:51 »
James,
Thanks for the info. I do not have the manual. What amp is the fuel pump fuse, 8? My fuse is popping and I cannot find the short.
MBP
Maistran (MB)
230sl
Full Member
Platinum
Re: Fuses Ratings
Reply #3 on:
February 04, 2008, 22:16:50 »
Yes, it looks like fuse #4 is "fuel feed pump" = 8amp
Inactive
Platinum
USA, NY, New York
Re: Fuses Ratings
Reply #4 on:
February 05, 2008, 03:24:04 »
A fuse question: the fuse diagram in the fuse box cover does not list any devices for Fuse #3...the wiring diagram shows this fuse as grounded and going nowhere if I read the diagram correctly.
What is Fuse 3 used for?
Richard M, NYC home of the miracle NY Giants Football team. (Sorry New England but you did have all the apples except the Big Apple!)
Full Member
Platinum
Re: Fuses Ratings
Reply #5 on:
February 05, 2008, 07:28:31 »
does anyone know of anyone selling a "set" of all the fuses? Seeing as they are generally now old and often have difficulty retaining good contact, I was thinking of replacing them all in one fell swoop
graphic66
Re: Fuses Ratings
Reply #6 on:
February 05, 2008, 08:09:30 »
When replacing fuses dab a small amount of silicon dielectric compound on the contact areas. This will keep them from corroding so quickly. Also every so often give the fuses a twist to help clean them. Did anyone see the last set of fuse pliers on Ebay go for $90.00? Glad I have a set, they do make the fuse changing very easy. Before installing also take some fine emery cloth and clean the fuse and fuse holder contacts so they are clean. Sometimes you need to gently bend the holders in to get a little more tension on them also.
blue230sl
Re: Fuses Ratings
Reply #7 on:
February 05, 2008, 08:15:05 »
you can find all sorts of fuse sets in Ebay Express, at reasonable prices
john
64 230sl euro 4 spd
89 190e 2.6
68_white
Full Member
Senior
USA, TX, Houston
Re: Fuses Ratings
Reply #8 on:
February 09, 2008, 21:11:20 »
Graphic66,
That was my $90. I have seen these pliers go for as much as $300.
Also, I think the two 25 amp fuses are short. You can only find them from sedan parts cars. No longer available from auto stores.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
Re: Fuses Ratings
Reply #9 on:
February 17, 2008, 01:47:57 »
May be its me and I am doing something wrong. I have two orginal black fuse pliers early and late and can never get them to work. the short fuses can be purchased from buds Benz. It took me an hour to get the darn little sucker fuse back in. no wonder no one likes changing these fuses. The fuse numbers and discription should be on the back of the fuse cover under the plastic sheet of protective cover. It may also be in the work shop manual, but I have never checked this.
Fuses Ratings
