Author Topic: Battery Recommendations (and/or size) please.  (Read 8518 times)
toml
« on: January 02, 2008, 15:47:50 »
My alarm/amplifier seems to do a slow trickle drain on my battery when stored during the winter. After a couple complete drains, I made the smart move of getting a Battery Tender. But it was likely too late as another accidental drain and I can't seem to charge that battery anymore. So time for a new one.
1. Should I get a mercedes benz branded one if they even make them for our car and is that dealer only (how much)??
2. I seem to recall seeing posts saying that only Interstate brand batteries are considered concours worthy if not an MB battery. Do people go with interstate because they are as good but cheaper than MBs?
Basically, I've never bought a battery before, so no detail is too dumbed down for me. If you can tell me an exact model or dimensions, or amp/crank specs, I would very much appreciate it. (this is for a '64 230).
Thanks, oh and Happy New Year!
TomL, Portland, OR
1964 230SL Euro 4-speed Silver+Black w/ Red Interior
1973 280C DOHC Metalic Blue w/ Tan interior
Re: Battery Recommendations (and/or size) please.
« Reply #1 on: January 02, 2008, 18:11:47 »
Tom,
The ONLY reason to get a Mercedes branded battery at its high cost is if you are showing your car in an MBCA Concours d'Elegance.  You'll get points taken off for anything but; the reason is the standard is "as delivered" or with original parts.  Interstate, DieHard, or anything else won't do.
Not that many show to this standard; in that case my first choice would be an Optima Gel.  Others have them and will eventually pipe in here with the size/model.
Mercedes-Benz Club of America
« Reply #2 on: January 02, 2008, 22:18:57 »
A battery Group 24-F size is the battery that I have always installed as replacements in a pagoda SL.
The F refers to the reversed polarity of the battery posts, if you get a standard group 24 battery the + post could short against the hood when it is closed.
Al Lieffring
66 230SL
« Reply #3 on: January 03, 2008, 12:24:42 »
A Benz battery is about $160.00  You can get a regular battery for half that amount.
« Reply #4 on: January 03, 2008, 14:24:12 »
John
Originally posted by thelews
graphic66
« Reply #5 on: January 04, 2008, 12:18:05 »
This is from my earlier post, it is a great fit- The batteries I have used, that claimed to fit, never fit very good at all. I took the tray and top to the store and ended up getting an Energizer part# e36R with 810 cranking amps and 650 CCA. This is not for everyone, because you must grind off one of the plastic mounting lips on the front bottom edge of the battery to fit the tray. If you do that it fits perfect, the top holddown fits perfect and the posts are correct. The battery was only $52.00 at Sams Club, thats the best part. It also looks great, just grind off the front lip so the exposed bottom back is clean. And it will bolt in and look great, all for only $52.00.
dldubois
  • USA, FL, Pembroke Pines
« Reply #6 on: January 04, 2008, 19:56:19 »
Anyone should have one that will fit.  I've got a Duralast 48-DL.  875 cranking amps and 700 CCA.  Fit perfectly in the tray after filing a little of the base (It had a little lip on the bottom)
Available at Autozone for $50-60.
Dana DuBois
1969 280sl
Corinth, TX
Dana DuBois
1969 280sl
Pembroke Pines, FL
