Author Topic: Shift Linkage  (Read 6548 times)
wit61
Shift Linkage
« on: October 05, 2007, 20:35:41 »
Does anyone have a photograph or a diagram of what this (circled) assembly should look like when attached to the shaft connecting it to the tranny and what hardware is involved? It is the hardware which connects the bottom of the shift lever (automatic) with the shaft which goes to the tranny/neutral switch. Looks like there is a plastic bushing surrounding an encapsulated metal faster ?? Any part #s would also be helpful...Thanks
64 230SL
1964 230SL Auto
1972 BMW 2002tii
If you go flying back into the past and you see someone flying forward into the future, it is probably best to avoid eye contact...
www.classicvelocity.com
« Last Edit: October 05, 2007, 20:47:19 by wit61 »
wit61
Re: Shift Linkage
« Reply #1 on: October 05, 2007, 20:54:51 »
now with pic
68_white
  • USA, TX, Houston
Re: Shift Linkage
« Reply #2 on: October 05, 2007, 21:48:32 »
My catalog 10202, which is for the 250SL and 280SL shows the part as 113 260 04 39 (lever). However, if you look at the SLS site:
you will find two versions. Clearly the 230SL (or early) version is somewhat different.
You may contact SLS for availability. Also, their diagram is fairly clear as to how it is assembled.  Cheers.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
mbzse
Re: Shift Linkage
« Reply #3 on: October 06, 2007, 08:57:59 »
Originally posted by wit61
Does anyone have....
Find all the info you need here:
http://sl113.org/forums/index.php?topic=3717
/Hans in Sweden
/Hans S
Re: Shift Linkage
« Reply #4 on: October 06, 2007, 09:09:58 »
ami
Re: Shift Linkage
« Reply #5 on: October 07, 2007, 03:05:36 »
if you go flying back into the past and you see someone flying forward into the future, it is probably best to avoid eye contact...
what does this mean please?
cars including SL's
