Author Topic: replace sychro rings/gears?  (Read 6237 times)
« on: August 10, 2007, 10:47:53 »
Bought a replacement manual tranny which I'm rebuilding.  Plan to replace 4 large ball bearings, seals and gaskets.  Gears and synchros look fine to me.  I'd like to hear from experts concerning if I should replace the synchro rings.  Here is a pics, I hope it shows sufficient detail for an evaluation.
Download Attachment: synchro2.jpg
40.88 KB
« Last Edit: August 11, 2007, 07:07:51 by jeffc280sl »
Re: replace sychro rings/gears?
« Reply #1 on: August 10, 2007, 12:02:17 »
Place the syncro cone on the gear with a little bit of trans fluid to lube the two pieces. Push down and try and twist the syncro ring in a radial direction. It should lock up right away and not spin at all. If it turns more than one or two mm it's probably no good.
« Reply #2 on: August 10, 2007, 12:25:08 »
Thanks Dan,
I'll give it a try and let you know.
« Reply #3 on: August 10, 2007, 12:58:08 »
Dan,
I think you are asking me to put the synchro ring back in place and then slide the synchro body over the ring.  Then while holding the synchro body firmy try to spin the synchro ring assembly to see if there is more than 1-2mm of play.  I have a very small amount of play in the 1-2 mm range so I guess its okay.  This test would seam to indicate that the width of the teath on the snchro ring are not worn too thin.  If it were too thin there would be more radial play when you slide the synchro body over it.
Should all 4 synchro rings have the same size teeth?  Most importantly width?
Thank you very much!
« Reply #4 on: August 10, 2007, 13:12:26 »
This picture, from a Porshe, would indicate wear of synchro rings takes place in the depth of the ring verses the width.  Is this the kind of wear we should be looking for?
Download Attachment: worn synchro1.jpg
62.42 KB
« Reply #5 on: August 10, 2007, 13:32:47 »
For my money I replace first and second gear syncro rings on every trans I filet. If you don't know what you are looking for in regards to gear and slider wear I would suggest taking the gears to someone who rebuilds transmissions for a look.
Hint:
Guys who rebuild large truck transmissions usually know what they are doing. The one thing they like to avoid is a pissed off truck driver.
« Reply #6 on: August 10, 2007, 19:27:08 »
No. You do this test by simply dropping the ring on top of a gear cone and seeing if it will move sideways. If it moves at all ( as per the test ) the ring is worn out.
« Reply #7 on: August 10, 2007, 19:37:18 »
Thanks again Dan.  The ring fits very snuggly onto the gear cone.  The undersurface of the ring looks to be in very good shape and the grooves on are very defined.
« Reply #8 on: August 10, 2007, 22:07:28 »
Looks like the sychronizer body 111 262 07 35 has some worn splines on top near the brass ring.  Pic attached.  Part is available at SLS for 86 euros.  I seems like the sliding collar which slides back and forth on the snchro body when shifting moved in one direction too far and ended up too near the end of the slines on the body causing wear.  I need to determine if a loose nut allowed for this kind of play.
Download Attachment: Manual tranny 055a.jpg
51.65 KB
« Last Edit: August 11, 2007, 10:38:33 by jeffc280sl »
« Reply #9 on: August 11, 2007, 10:37:03 »
Here is one of George's pics of the sliding collar that slides when shifting gears.  The loose nut is the same one he speaks about in his write up.
Download Attachment: 2006123163849_trans-mainshaft-sml.jpg
46.54 KB
« Last Edit: August 11, 2007, 10:37:29 by jeffc280sl »
« Reply #10 on: August 11, 2007, 16:11:20 »
The teeth and width is likely the same on all the syncros but 1st gear syncro usually has a wider piece or section on the oustside rim than the other ones.
« Reply #11 on: August 11, 2007, 20:09:35 »
Thanks Dan,
Now that I have it completely apart I can see that one of the rings has slots on the side that meets the gear cone.
