Author Topic: alt light stays on - new volt reg?  (Read 5775 times)
merrill
« on: May 14, 2007, 20:58:54 »
so, 66 230 sl, purchased a new voltage reg from K&K  MFG
bosch pn 0 192 062 007
MB part 002-154-74-06
started the car, the red light came on, drove the car  red light still on,  hmm,  the volt meter said 11.9 volts.
put old volt reg back on car = no red light.  and volt meter went up to 12.7 volts.
thoughts?
the alt has been on the car for quite some time.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: alt light stays on - new volt reg?
« Reply #1 on: May 15, 2007, 04:31:26 »
If the fan belt is loose the alternator will not put out enough volts under load.
merrill
« Reply #2 on: May 15, 2007, 06:59:15 »
I agree, however the belt is quite tight, very little deflection.
when I put the old volt reg on the light went off. no other change?
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #3 on: May 15, 2007, 17:15:15 »
Sounds like that new voltage regulator is defective, no?
merrill
« Reply #4 on: October 29, 2007, 20:08:13 »
problem solved,
using the fantastic color coded wiring diagram that I received in the pagoda world I found that I had wired the plug that goes into the alt backwards.
I had the DF and D+ wires reversed.
corrected the wiring and alt light went out and the volt meter seemed to hold the voltaage stable.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
