Author Topic: SLS lock set matched  (Read 6067 times)
Chad
« on: March 17, 2007, 00:59:46 »
SLS (germ) sells a complete lock set for 280SL that seems to include the door handles, fuel cap, trunk lid and ignition all keyed to the same.  The site is German so I am not sure if this is indeed the case.  Has anyone used this?  Is there any reason to not try this for the 230SL?  Meaning the ignition not being swapable, or some other thing I am just not thinking of?
It would be nice to have one key for the car, instead of three (sometimes four).  Although I realize this is not exactly original specs for a 230SL.
Thanks for any advice.
CD
1967 230SL
« Last Edit: March 17, 2007, 01:00:47 by Chad »
ami
Re: SLS lock set matched
« Reply #1 on: March 17, 2007, 03:00:04 »
There is an English flag to click for a translation. I believe it is only the barrels that change please. I may be wrong and I am not being rude by the way.
some cars including some SL's
« Reply #2 on: March 17, 2007, 03:17:07 »
Just looked at the SLS site. There is an English language button both on the home page (top left corner) and then again on each page (top right corner). However, not everything is actually available in English, including the lock/key information.
The set they sell seems to contain all items containing a lock completely: gas gap, door handles, trunk lock, even glove compartment lock and costs almost EUR 600, i.e. about $780. This is for the 280 SL as from 9/69. According to the information provided, it is possible to convert older models to the one-key system, starting with the 250 SL chassis number 2980, however then some parts of the steering column will have to be modified, up until the 280 SL 9/69 mark.
Maybe it is best to send them an email with your vehicle data and a description of what you are looking to achieve.
P.s. Ami - I am getting used to your style of English now!
« Last Edit: March 17, 2007, 03:18:02 by cees klumper »
« Reply #3 on: March 17, 2007, 07:34:03 »
Hello, Chad,
I do have one such set in my vault  :|
The ignition lock on the 230/early 250 is completely different (Niemann as opposed to Hu????) and therefore not interchangeable.
The door handles have a different operating jaw but these could probably be swapped over.
I believe the glove box lock and trunk lock would change over and the fuel cap would fit too.
You could end up with 2 keys instead of your present 4?
erickmarciano
  • Canada, Quebec, montreal
« Reply #4 on: March 17, 2007, 10:52:00 »
anyone got a bad late 280sl fuel cap only need the barrel
thanks
2004 Volvo s60 T5
1971 280sl
1962 VW bug
1971 Harley FLH
1963 gs160 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Chad
« Reply #5 on: March 17, 2007, 21:22:02 »
Hummmm. I will formulate an email including VIN to SLS to see what the packages can do for my VIN.  It would be nice to get down to an ignition key plus one other.
Thinking - not experienced with lock changes, perhaps a locksmith can adjust/swap tumblers to make the glovebox, doors, gascap, boot use one common key - is this a dream?
1967 230SL
« Reply #6 on: March 18, 2007, 06:41:39 »
Chad,
No, it has been done before... :)
Chad
« Reply #7 on: March 18, 2007, 07:45:27 »
Fantastic... I will visit my local locksmith this week.  Two keys (ignition and all else) I can live with.  Three keys has always seemed absurd.
1967 230SL
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #8 on: March 19, 2007, 18:09:43 »
Hi, Erick,
When I bought my 230, it had a later gas cap (280-style double-cut key).  I eventually found a 230 tumbler that matches my doors (as original), so I swapped it into my gas cap.  I believe that I have the old (newer) gas cap tumbler and key in my garage.  Wanna' swap for an old Vespa?  Just kidding.  Send me an email, and I'll send you the tumbler.
-David Pease
'66 French 230SL
-David Pease
hencal
« Reply #9 on: March 20, 2007, 14:33:36 »
I fitted the one key system from SLS to my 1968 280 SL. Works beautifully.
erickmarciano
« Reply #10 on: March 21, 2007, 08:02:53 »
thanks David for the offer . did you get my email?
thanks again
Erick
2004 Volvo s60 T5
1971 280sl
1962 VW bug
1971 Harley FLH
1963 gs160 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #11 on: March 21, 2007, 13:45:38 »
Hi, Erick,
Yes.  I will look for the parts this weekend, and let you know when I've sent them.
-David Pease
'66 French 230SL
-David Pease
« Reply #12 on: March 21, 2007, 15:41:17 »
Had a key problem with the passenger door.  PO must have replaced the handle/set but not rekeyed the lock.  I took it apart and was able reorder the key plate pieces and use all but one of them.  I just left it out.  The lock is not as secure because it has 9 of 10 plates that line up with the key to lock/unlock.
It was a simple job not unlike doing a lockset for your home door.  Wish I had taken pics.
