Author Topic: I was told to use gear oil in my 4 sp is this ok ?  (Read 5666 times)
erickmarciano
  • Canada, Quebec, montreal
« on: August 24, 2003, 20:33:12 »
since I do not use my car in cold weather I was told to use gear oil in the 4 speed transmision is this corect or should I use ATF
thanks
Erick Marciano
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: I was told to use gear oil in my 4 sp is this ok ?
« Reply #1 on: August 24, 2003, 20:43:51 »
Hello Erick,
These standard transmissions are designed to run with automatic transmission fluid. I have always used ATF.
Albert-230SL
« Reply #2 on: August 25, 2003, 03:50:41 »
Agree with Joe,
You should use ATF. A Mercedes mechanic warned me that normal gear oil could damage the gearbox (there are some ball bearings which are not lubricated with the thicker oil)
Albert de la Torre Chavalera
Barcelona (Catalunya/Spain)
« Reply #3 on: August 25, 2003, 19:25:56 »
Anyone know why you're to use ATF and not gear lube? There's an actual reason why.
Dan c
Daniel G Caron
