Author Topic: braking up at3500-4000 rpm  (Read 4924 times)
gp racer
« on: January 21, 2007, 07:18:46 »
Runs fine up to about 3500 rpm and the it starts braking up, it will not pool over 4000 rpm or so. Also where can I find a complette fuel systemm schematic including the electrical parts.
 Thanx.
  Lajos
gp racer
Re: braking up at3500-4000 rpm
« Reply #1 on: January 21, 2007, 07:27:10 »
It's a '64 230 sl.
Lajos
mille
« Reply #2 on: January 21, 2007, 08:22:00 »
Lajos,
I had a similar problem with our 1964 230 SL and it was down to lack of lubrication of the distributor, which affrected the timing advance/retard function. Try the following: Take off the distributor cap. Remove the rotor. The rotor axle is hollow and you should let a few drops of engine oil into the hollow shaft. Next, place the rotor and distributor cap. Furthermore, you will find a small oil cap on the side of the distributor. Turn the knob until open and add a few drops if engine oil. I is important to be a little patient as the oil have to work.
Good luck
/Finn
1964 230 SL Euro 4-speed manual silver & black leather
« Reply #3 on: January 21, 2007, 09:28:18 »
Hello Lajos,
What is the history of this problem?
Read the spark plugs and install a new set.  Spark plugs are inexpensive compared to everything else.  You can use the old set again later if the problem is somewhere else. Check back with us after the change.
« Last Edit: January 21, 2007, 09:28:51 by ja17 »
gp racer
« Reply #4 on: January 21, 2007, 09:44:42 »
Hello Joe,
 It's been years since I've seen You, any way , the car belongs to one of my costumers, it was towed in, The coil was oosing, the dist. had a short, replaced everything, it runs fine up to 4000 rpm. If You don't mind You can call me at 614 378 6366.
   Thanx,
   Lajos.
JimVillers
  • USA, VA, Virginia Beach
« Reply #5 on: January 21, 2007, 12:16:25 »
I'm with Finn .... The problem is in the ignition system.  Are you sure that you installed the correct coil?  An internal ballast coil with external ballast would cause your symptom.  Check the resistance on the coil, if it is greater than 3 ohms, it should not have the external ballast.
Jim Villers
Jim Villers
gp racer
« Reply #6 on: January 21, 2007, 15:50:53 »
I've installed a BLUE coil, what is te resystance of a blue coil?
   Thanx,
  Lajos
JimVillers
« Reply #7 on: January 22, 2007, 07:55:25 »
The blue coil has an internal balast.  The red coil is standard for the 113s.
Jim Villers
Jim Villers
« Reply #8 on: January 22, 2007, 09:35:45 »
Lajos,
Another Columbus person, welcome!
Group,
Wasn't someone here building a document that listed the different "matching sets" of ignition components?  That would be very helpful to many people!
« Reply #9 on: January 22, 2007, 12:54:38 »
   Thanx,
  Lajos
Lajos
Not all of the blue coils are compatable with point and condensor ignitions, I had the same problem when I tried to use a blue Bosch TSZ coil on my 66 230sl.
here is a thread where it was discussed
http://index.php?topic=5988
al
66 230sl
113-042-10-014715
904/396 blue, Ivory Tex
