Author Topic: typical rpm range  (Read 6048 times)
typical rpm range
« on: December 22, 2006, 10:32:19 »
In what range should the rpm's be in my '71 280SL when cruising at 50 mph?  Thanks for the info.
Re: typical rpm range
« Reply #1 on: December 22, 2006, 10:40:27 »
« Reply #2 on: December 22, 2006, 10:47:41 »
Thanks Jeff
ted280sl
  • USA, NY, New Rochelle
« Reply #3 on: December 22, 2006, 14:14:50 »
I believe there are some variables to consider in answering this question. Automatic or standard. If standard, 4 speed or the rare 5 speed. Which rear end is installed. The Euro models had a smaller rear end and therefore lower RPM's at highway speeds.
  I hate to confuse the issue but, I thought this information would help.
Ted 280SL w/ 4 speed and Euro rear end
Abbas
« Reply #4 on: December 23, 2006, 03:18:30 »
Ted,
  I wonder why the Euro models had a smaller ratio and lower RPM than US version. Does this have to do with regulation or .... it is quite interesting to know. Actually, the high RPM is quite anoying some times - you feel that the car is making a huge effort and quite noisy/furious  :) .
Abbas
280SL W113 1969 Ivory
E280 W124 1995 Silver
« Last Edit: December 23, 2006, 09:23:59 by Abbas »
« Reply #5 on: December 23, 2006, 09:15:36 »
U.S. model, 4 speed automatic - Jeff's number of app. 2600 rpm is right about what I am seeing
Klaus
« Reply #6 on: December 23, 2006, 09:29:58 »
Abbas,
regulations are involved inasmuch as the US always had lower speed limits. Therefore, engineering and marketing concurred that European models had to have a high top speed (200 kmh was the design target), while US models had to have better acceleration.
Klaus
1969 280 SL
Abbas
« Reply #7 on: December 24, 2006, 01:01:11 »
Abbas,
Klaus
Klaus, from this I would understand that MB on purpose made the US version cars with higher ratio so that people cannot drive them at higher speed. Can this be changed by tuning the car or we have to change the whole differential.
Abbas
« Reply #8 on: December 24, 2006, 07:26:06 »
Abbas,
I've recently changed out my rear axle in favor of an axle from a 1972 280SE 4.5.  The V8 Mercedes had a 3.27 ratio rear axle.  Do a search on this subject and you will find a lot of information.
« Reply #9 on: December 24, 2006, 12:53:51 »
I think the gearing in the US was market-driven.  US drivers were used to big, torquey V-8 motors that accelerate quickly.  The lower gearing gives the car somewhat better acceleration.
« Last Edit: December 24, 2006, 12:54:16 by George Davis »
« Reply #10 on: December 25, 2006, 00:33:58 »
I changed my differential over from 4.08 to 3.69. There is obviously a difference, however it is not that significant. On the highway, the car still revs much higher than one would expect a six-cylinder to do. Converting all the way to a 3.27 would help somewhat more, however as noted the acceleration would suffer appreciably. I have just gotten used to the fact that this engine actually likes to rev high.
