Author Topic: Bottom bullet bumpers for lower A arm?  (Read 3375 times)
Jazn
« on: December 01, 2006, 15:21:12 »
Anyone have a trick to getting these back into the lower A arm?
jason
Re: Bottom bullet bumpers for lower A arm?
« Reply #1 on: December 01, 2006, 17:31:44 »
Hello Jason,
The sping pressure will be fighting you.  Try a block of wood and a floor jack under the A arm to help align things up.
« Reply #2 on: December 02, 2006, 07:55:13 »
Jason,
If you are referring to the 2 rubber bumpers (stops), these are a bit hard to install when the bumpers are new.  Seems the rubber is larger than the housing, and the rubber fights against you...
To install mine, I ended up sanding a couple of mm off of the rubber (sand only to the depth of the metal housing whichs holds the bumper).
Using gloves to get a better grip, as well as some silicon spray lube on the rubber section being insterted, I turned the bumbers while applying some downward force.  Sort of screwed them in...
Very tight fit, but they went in and have held up well!
Good luck!
« Reply #3 on: December 04, 2006, 15:50:14 »
How about putting the rubber pieces into a pot of water and bring to boil and then quickly install.  The rubber is more pliable and a bit of windex window washer can help in getting them in.  Wd-40 is a soluble oil, and will keep the rubbers slippery and can pop out again.
Walter
1967 220SL-diesel
