with our official
Pagoda SL Group logo
from our official partner.
General Discussion
Top Latch on Hard/Softtop is loose
Topic: Top Latch on Hard/Softtop is loose (Read 3674 times)
vincesy
October 27, 2006, 17:40:31 »
Does anyone have problems with the hardtop's top latch coming loose during driving? I have this problem even with the soft top. I'm wondering if there's an easy way to fix or adjust this. Thanks.
Re: Top Latch on Hard/Softtop is loose
October 27, 2006, 19:11:19 »
It's possible that the rubber washers that sit around the locking pins need to be replaced. I replaced mine and it has made the softop and hardtop tighter against the windshield. Easy to replace!
bpossel (Memphis, TN.)
'71 280SL / '97 E320
vincesy
Reply #2 on:
October 30, 2006, 00:50:33 »
Bob, thanks for the advice. Is it something that one can just fish out and replace with new washers? I don't see washers around the locking pins. Maybe that's why I have this problem?
Reply #3 on:
October 30, 2006, 06:22:24 »
SLS carries these hard rubber washers. They simply slide over the locking pins (no glue) on both the hard top and soft top. They are a very tight fit, stretching a bit while sliding over the pin.
Click on this link and scroll down to the softtop page. Refer to item #43 (Buffer ring on lock)
http://213.239.220.84/bin/dbframes.phtml?mid=IN02
Last Edit: October 30, 2006, 06:24:51 by bpossel
vincesy
Reply #4 on:
November 05, 2006, 16:15:48 »
Thanks for the advice. I've ordered the rubber washers and hopefully this cheap and easy solution does it. I don't even know how long the car has been without these washers.
Vincent
General Discussion
