Author Topic: need tips for removing injection pump  (Read 5375 times)
merrill
« on: October 04, 2006, 17:53:51 »
so, I need some tips on removing the injection pump on my 230 sl.
I have all but 2 nuts securing the injection pump to remove.
I need a tip on how to get to the lower nut that secures the pump to the motor.   This is the one about 6 o clock.  the other one at 9 o clock is the other nut left to remove.
is access to the 6  o clock nut only accessable from below?  I cannot get a wrench on the nut when reaching in from the drivers side fender.
thanks
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
dwilli3038
Re: need tips for removing injection pump
« Reply #1 on: October 04, 2006, 18:21:01 »
I found that the only way to get to it was from below
Daryl
'77 280SE
« Reply #2 on: October 05, 2006, 09:45:15 »
Hello Mat,
I use a  13mm  swivel socket and a 10" (approx) extension  (all 1/4" drive) and remove it from above.
« Reply #3 on: October 05, 2006, 16:16:27 »
I am pretty sure on my 280 SL I can remove all nuts from above, using standard Craftsman wrenches (don't own swivel tools).
nate
« Reply #4 on: October 05, 2006, 16:39:57 »
Out of curiosity, how many hours of labor including r&r are involved in?  What cost is involved to have an injection pump rebuilt?
merrill
« Reply #5 on: October 05, 2006, 18:11:14 »
finall got the lower bolt off by reaching up from below the car.
still was not easy to get to
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
dwilli3038
« Reply #6 on: October 05, 2006, 18:21:47 »
It took me a couple of hours to remove my pump. The net you are strugling with was actualy missing. I paid around $600 for Jerry Fairchild to rebuild my pump. It took me three hours to put it back in. The car started readily after the rebuild. It did need to be adjusted as it was a little lean. For the adjustment it took the skillfull touch of Al Leifring
Daryl
'77 280SE
dwilli3038
« Reply #7 on: October 05, 2006, 18:26:41 »
Nate, I advise caution before a rebuild. My car was abused by the PO...if yours was not abused it may not need rebuilding. Chck your gas filter to asure you do not have rust, check your fuel pump and your injectos before considering a rebuild
 nate Posted - 05 Oct 2006 : 18:39:57
Daryl
'77 280SE
PnHi
« Reply #8 on: October 06, 2006, 07:40:46 »
merrill
I never could get that nut off completely from the bottom or top.  As I recall something was in the way that was even harder to get to. Maybe the oil cooler.  Anyway after trying for days I gave up bolted it back up, concentrated on everything else that could have been the reason for rough running and added a pint of 2 cycle motor oil with the first tank of gas.  Rough running continued for awhile, but it eventually smoothed out and currently runs great with idle rpm at 700.  That was in 1999.
Mike C.
1968 250SL
Dark Green/Cognac
merrill
« Reply #9 on: October 06, 2006, 18:09:13 »
Mike C,
funny thing, the bolts that secure the inj pump to the motor were 13 mm.  I ended up using a 14mm on the lower bolt as the 13 would not line up.  I will try a swivel attachment between the socket and ratchet when re installing the pump.
that lower bolt is a pain to get to, as one has to reach above the fuel filter to get to that lower bolt.
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
