Author Topic: Will not hot start  (Read 16782 times)
Re: Will not hot start
« Reply #25 on: September 01, 2006, 04:45:48 »
Restrictions in the fuel delivery lines will cause changes in the sound of the electric fuel pump. A dirty fuel tank screen and especially the fuel screen in the electric fuel filter will change the tone of the electric fuel pump. The first step to solving any chronic starting problems is to be sure the fuel supply and volume is correct. Make sure the fuel tank screen, electric fuel pump screen and main fuel filter are clear. Check the volume and fuel pressure at the engine afterward. The earliest versions of the electric fuel pump on the 230SL did not have the screen built in them.
Most of these engines have the injection pump enrichment solenoid. This will activate  any time the starter is activated. Make sure this solenoid and its relay is working. This will effect hot starting if it is not working properly.
I recently worked on a W113 which had chronic hard starting problems for years. The injection system was set much too lean and after sitting for about 20 minutes  would not restart. The rise in engine temperature after shut down causes the WRD to lean out the fuel mixture even more, causing the hot start problem. The spark plugs were "snow white" indicating the much to lean mixture. After the mixture was richened  the spark plugs showed a nice tan color and the hot start problem disappeared.
dwilli3038
« Reply #26 on: September 03, 2006, 07:08:53 »
Yesterday afternoon, I drove over to Al's place and let him work his "magic". While several things were adjusted, the most major thing seemed to be it was set way too lean. It now starts well when hot. :D  I was able to see Al's recently rebuild engine still on the engine stand.
Al is certainly a knowlegable and helpful member of our group. In addidon to his Pogoda he is working on he has at least 15 unicycles of various configurations. It certainly was a most enjoyable afternoon
Daryl
'77 280SE
