Author Topic: Ventilator Box vs. Heater Core  (Read 4448 times)
ChrisInNashville
  • USA, TN, Nashville
« on: July 02, 2006, 07:27:45 »
I expected to have my heater core replaced last week. The ventilation wires froze up after a dash restoration last year.
Anyway, my new mechanic indicated that he doesn't feel that it's the heater core, but rather the ventilator box.   Unfortunately, I don't find any references to ventilator box on this forum or the on-line parts sources.
The part is on a four week shipment from Germany, so I have time to research the issue.   I guess as a practical matter it may not matter since either way it involves dash disassembly...but will this fix the problem?   The heater/ventilation system was otherwise operational before the wires froze up...
Does anyone have insight to offer on this?   Where is this ventilator box?
‘69 280 SL
‘24 GLE450e
Tennessee, USA
enochbell
Re: Ventilator Box vs. Heater Core
« Reply #1 on: July 02, 2006, 09:26:38 »
The box is directly below the heater core.  The heater/air flow levers operate the louvers (simple mechanical flaps attached to the cables operated by the levers)and are just about bullet proof.  Your problem likely rests with the cables themselves, they probably need to be lubed.  The crude hinges on the flaps can also be lubed.  In the worst case the cable(s) were kinked during reassembly.  In any case, all will be revealed when you remove the box and inspect the operation.  There are several other posts on the removal process, it is a bit difficult... the bottom keeper bolt/nut go through the tunnel and you will probably need to fish a spanner from underneath the car, directly above the front transmission housing.  Once released, the box slides right into th passenger footwell.
The other common problem is for the bracket on the side of the heater core to separate from the core itself, causing the cable to the valve to be ineffective (moving the cable then only moves the box, without fully-opening or closing the valve).  If this is the case, it can be brazed on by any radiator shop.  And, BTW, there is an access hole to release the cable to the heater valve located in the engine compartment/firewall.  I learned about that the hard way :-)
g
graphic66
« Reply #2 on: July 02, 2006, 09:44:43 »
The arms on the rather expensive heater flaps also break, namely the one on the drivers side that is so cleverly hooked from the lever to the flap to the heater core.
« Reply #3 on: July 02, 2006, 11:18:19 »
Here are some diagrams.  Should help you sort it out.
Good luck!
Download Attachment: heater.jpg
14.91 KB
Download Attachment: heater1.jpg
23.31 KB
ChrisInNashville
« Reply #4 on: July 02, 2006, 18:05:34 »
Thanks guys.   I think the winter project has been chosen...
‘69 280 SL
‘24 GLE450e
Tennessee, USA
« Reply #5 on: July 02, 2006, 19:08:41 »
This is a project that has potential for many projects within a project.  If you need to take the heater core out you might consider taking the gauges out for cleaning, replacing heater levers, recovering cracked dash pieces, refinishing wood trim and cleaning the wiper mechanism which goes through the body for the wiper arm.  I'm sure someone can think of more items to look at while in the dash area.
ChrisInNashville
« Reply #6 on: July 04, 2006, 19:14:43 »
Thanks Jeff.   Unfortunately, it was during the 6 week wait for the plastic housing unit on the heater slide light.
I will however be getting the A/C worked on and cleaning out tons of graphic dust that the former owner used to "prime" the heater slides.
‘69 280 SL
‘24 GLE450e
Tennessee, USA
