with our official
Pagoda SL Group logo
from our official partner.
General Discussion
talc (talcum powder) removal
Topic: talc (talcum powder) removal (Read 9995 times)
paults1
Full Member
Senior
USA, FL, The Villages
June 15, 2006, 21:00:41 »
Talc is used to lube rubber gaskets or seals. The new seals on my soft top have way to much talc on them. When I close the doors with the windows up, it looks like a snow storm inside the car. Anyone have suggetions as to what to use to remove this excess on the seals. I tried dry brushing and soap & water. The talc just seems to keep multiplying!
Paul, '63 230SL
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Re: talc (talcum powder) removal
June 16, 2006, 06:32:03 »
Can you pull it off with masking tape? That should not leave behind any sticky residue.
113gray
Reply #2 on:
June 16, 2006, 17:52:01 »
I just replaced seals between w'shield posts & front edges of side windows using MBz parts. The gummy white stuff covering the rubber was a PIA to remove & I'm guessing this is the same as your problem. Soap/detergent didn't budge it but mineral spirits removed it immediately. Try it on a small area of yours & see. -JP-
Reply #3 on:
June 17, 2006, 13:06:37 »
I have never heard of white powder look on factory Mercedes benz seals. I have some new seals and they are not white looking. Try some 303 rubber protectant availible at most RV stores and camping stores. If you have after market seals I have seen this problem, no mater what you do the seal returns with a white powdered look.
Last Edit: June 17, 2006, 13:07:28 by Bob G
dwilli3038
Reply #4 on:
June 17, 2006, 19:21:18 »
I just replaced the seal on one of the windows on the hard top (a real hemroid for sure) I did use Mercedes seals and there has white residue on it. I will wait until i do the otherside and the rear to try removing this material.
Daryl
'64 230 SL
Serial # 508
General Discussion
