Author Topic: Steering wheel composition?  (Read 9808 times)
Jazn
« on: June 04, 2006, 11:05:27 »
Anyone know what our steering wheels are made of?
Is it just a hard plastic?
Re: Steering wheel composition?
« Reply #1 on: June 04, 2006, 16:54:05 »
Hello Jazn,
Yes, they are hard plastic with a metal rod inside. Some people have restored these by filling cracks with epoxy and refinishing with a tough two stage industrial grade paint. I don't know how well these hold up.
« Reply #2 on: June 04, 2006, 17:10:03 »
I have done two w/epoxy and they have held up great.
 One thing I did do before the epoxy was to use CA glue on any crack that had exposed the metal skeleton ring ..don't know if that helped, but so far , so good..
ted280sl
  • USA, NY, New Rochelle
« Reply #3 on: June 05, 2006, 07:05:34 »
Jazn,
  I filled the cracks on my steering wheel and refinished it. It took a while but, it cam out looking great. I put it back on the car and the cracks cam back. I wet out and bought a new steering wheel. I beleiev the cost was $165. It looks great and no new cracks.
Ted 1969 280SL
Lilly
« Reply #4 on: June 06, 2006, 00:56:24 »
Hard plastic ?  I was under the impression that the white MB steering wheels in the W113 were made of ivory.  Will the all-knowing Master Pagoda please clear up this confusion ?
vincesy
« Reply #5 on: September 15, 2006, 18:22:21 »
Can someone help provide the specifics of the epoxy or the industrial grade paint that they used or can be used to fill cracks on the steering wheel?
« Reply #6 on: September 15, 2006, 18:53:05 »
The very original ones were made of genuine Ivory obtained from the Ivory Coast. The black ones were obtained from the Black Coast and made from black corral. Recent changes in the law have resulted in restrictions on the import of Ivory and black corral.
« Reply #7 on: September 16, 2006, 12:02:37 »
Did the green ones come from Greenland? ;)
enochbell
« Reply #8 on: September 16, 2006, 16:38:30 »
Engineer,
You are usually spot-on, but on this subject you missed: the very early black ones were actually black rhino tusk.  The changeover was mid-65 230sl, I think?
g
« Reply #9 on: September 16, 2006, 17:04:22 »
So, how many rhinos or elephants needed per steering wheel? :?: [:0]
George Des
« Reply #10 on: September 16, 2006, 17:06:56 »
I did mine with PC-7 epoxy. You need to first undercut the cracks with a Moto-Tool and fine tip to give the epoxy something to bite onto. The whole wheel needs to be sanded with a medium grade of sandpaper--about 380-400--primed with epoxy primer--I used PPG DP 90--and then finish painted with a base/clear (blk base) PPG acrylic urethane--I used DCC Concept. Wheel looks like new and the paint holds up very well. I believe you would have problems if you use anything other than a urethane paint.
George Des
KevinC
« Reply #11 on: September 17, 2006, 08:32:40 »
Hate to ask how they get zebra wood.
Kevin Caputo
Boca Raton, FL
1967 230 SL Automatic
670 Light Ivory
113 Bronze/Brown MB Tex
vincesy
« Reply #12 on: September 17, 2006, 21:28:49 »
George, thanks for the tip.   I also found some tips from other people restoring steering wheels for their older cars.
http://www.thebugshop.org/bsfqstrg.htm
http://fedora.net/falconaut/tech/steering_wheel.html
It also seems like restoring steering wheels is a more common project than I thought, requiring more patience than money.
I even found a kit out there for such a project.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemType=PRODUCT&RS=1&itemID=2569&keyword=52194Z
I misjudged how much more visible the cracking will be on an ivory steering wheel.
George Des
« Reply #13 on: September 18, 2006, 04:38:35 »
When I did my wheel several years ago, I believe I tapped into the two primary web sources you cited. The advice on them is a very good guide to follow. Good luck
George Des
joelj
« Reply #14 on: September 18, 2006, 17:06:08 »
Black Rhino tusks? real ivory?? Wow!! I better start looking for the old steering wheels :) this will be a collectors item :)
Joel
Engineer,
g
1969 280sl auto
White exterior
Blue interior
« Reply #15 on: September 19, 2006, 11:38:40 »
Don't forget about the moon rock shifter handles that came into vougue after the Apollo missions!
« Reply #16 on: September 19, 2006, 15:43:08 »
Kevin Caputo
The Zebra wood is created by glueing alternating plaques of white and black wood together using Gorilla glue (don't ask). The white wood is usually sourced from Ivory coast, and the black from the Black Coast.
« Last Edit: September 19, 2006, 15:44:18 by cees klumper »
joelj
« Reply #17 on: September 22, 2006, 08:35:25 »
Cees,
that was a funny post. I've never heard of the black coast. would the red interior come from the red sea by any chance? hehe
cheers,
Joel
Kevin Caputo
1969 280sl auto
White exterior
Blue interior
