Author Topic: Heater Hoses Replacement  (Read 3736 times)
« on: May 25, 2006, 09:57:31 »
I am planning to replace the hoses that connect from the engine to the heater.  I would like some advice on whether I need to drain the coolant to do this.  If I do not drain the coolant, how much will I lose?
Louis 70 280sl Red Auto
Re: Heater Hoses Replacement
« Reply #1 on: May 25, 2006, 10:39:18 »
When was the last time you drained the coolant?  It should be done every 2 years, I believe.
« Reply #2 on: May 25, 2006, 12:42:33 »
The coolant was replaced about year and a half ago. I want to know if I need to plan to replace them.
« Reply #3 on: May 25, 2006, 12:47:34 »
Just about whats in the matrix and hoses, maybe 1 liter
ted280sl
  • USA, NY, New Rochelle
« Reply #4 on: May 25, 2006, 19:06:37 »
Louis,
  The heater hoses are about the highest point of the cooling system. If you drain some coolant out you will be OK. The real challenge is re-filling they system and getting the air out. Some of our cars have a bleeder bolt on top of the thermostat.
Ted 1969 280SL
« Reply #5 on: May 25, 2006, 20:35:57 »
Thank you for the help. I will drain some coolant before I start.  I am planning to replace the thermostat anyway.
