Author Topic: Checking the Oil  (Read 3900 times)
Checking the Oil
« on: May 15, 2006, 16:04:44 »
Okay. So you would think I know this by now (19 years+)...Does one generally check the oil level with a cold engine or a warm one?
Ricardo
Re: Checking the Oil
« Reply #1 on: May 15, 2006, 16:45:20 »
I don't think it really matters as long as you let the warm engine sit for at least three minutes according to recent service bulletins from MB....
« Reply #2 on: May 15, 2006, 22:05:54 »
Well, whenever I check it warm (or anytime in the day after a ride) it reads full. When I check it stone cold its low about a 1/3 inch on the stick. Normal?
psmith
« Reply #3 on: May 15, 2006, 22:08:43 »
Hi James,
I always drive my car until it's up to operating temperature, and then turn it off and let is sit for a few minutes so the oil can all drain back into the pan.  The theory is that it will expand with temperature, but you want it all back in the pan before you measure it.  How was your drive back after last week's First Sunday Drive?
Pete S.
Ricardo
« Reply #4 on: May 16, 2006, 06:43:26 »
To add further to this issue...the service bulletin that stated the need to wait before checking, (which I can't find at the moment)also stated that the marks on the dipstick were indicators of too low and max. and that the actual correct level was in the middle of these two marks. This was in reference to modern benzes and the apparent issue of overfilling, due to the level being checked before allowing the engine to rest long enough. I'm not sure if the same applies to our vintage cars and I think this has been thrashed about before, but perhaps anyone who knows the right answer could chime in....
Fill to the max. line or half way between the two?
I think if you fill to the max. line on newer cars , they tend to "use" more oil or at least they drop to the half way mark rather quickly. I also understand that it raises crankcase pressure if you overfill them and this can lead to leaking seals....
« Reply #5 on: May 16, 2006, 11:34:56 »
Well, I usually check the oil when I fuel up, or sometimes at home. The engine is usually warm -- and I keep the level at the top of the second "section" of the stick (max). Reason I questioned this is I checked it once after a few idle days -- engine cold -- and it was low. I decided I'd check it again when I get gas and sure enough it was back to full. So I guess I'm ok/ Thanks..
Hey Pete, the ride home was fine. Usually the ride home from anywhere fun is a bit of a bummer -- but not in the Pagoda! I put the soft-top back up and kinda hauled butt (for me). Made it home in 2.5 hours. Car ran great, and I got darn good mileage. On that home stretch of highway we got 23 MPG and for the trip overall 20.5. Thanks for a fun day.
