Author Topic: Ignition  (Read 5234 times)
jasperlabrador
Ignition
« on: May 09, 2006, 08:08:34 »
I am seeking an ignition barrell plus the chrome surround for a RHD, 1966 Pagoda - can anybody help?
Re: Ignition
« Reply #1 on: May 10, 2006, 05:09:38 »
It seems that these should be the same part in a right hand or left hand drive? Are you talking ablut the parts around the ignition key?
Re: Ignition
« Reply #2 on: May 10, 2006, 07:14:45 »
Go here and click on Steering Column inserts.
Thery have all the parts you will need.
  RHD/LHD show the same . The rings changed at mid .043 chassis, so use the early '67 insert
« Last Edit: May 10, 2006, 08:42:22 by A Dalton »
Re: Ignition
« Reply #3 on: May 10, 2006, 11:53:03 »
Hi, Edmond
Not sure what you mean by ignition barrell: if you mean the complete steering lock assembly, the one for a RHD 230 SL is part number: 000 462 2930. It is not the same as a LHD 230 SL.
If you need just the electrical part of the steering lock: 000 462 0693.
110 689 0180 Chrome surround
110 689 0098 Rubber ring behind chrome surround.
Hope this helps
« Last Edit: May 10, 2006, 11:55:45 by naj »
jasperlabrador
Re: Ignition
« Reply #4 on: May 11, 2006, 03:29:28 »
Originally posted by naj
Hi, Edmond
Hope this helps
jasperlabrador
Re: Ignition
« Reply #5 on: May 11, 2006, 03:33:15 »
Hi, Edmond
Hope this helps
jasperlabrador
Re: Ignition
« Reply #6 on: May 11, 2006, 03:35:25 »
Hello Naj.
the part I want is the barrell that the key fits into - i have the steering lock and everything else.
Regards and thank you,
Edmond
Hi, Edmond
Hope this helps
