Author Topic: - - more on speedometer issues - -  (Read 3312 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: April 27, 2006, 19:34:08 »
Hello all - - Sorry to be a nuisance on my speedo issues - - but - -
 I think I may have the answer to why my speedometer is so wildly inaccurate to the low side. However, I need a little more help to resolve this dilemma . I do not suspect the speedometer itself, it runs smoothly and is precise and quiet.
My car is a 230SL that was re-engined with a M130.980 some time long before I bought it. The transmission is correct for the sedan power-train also, that is, it's a GA 280 SE.  The differential ratio is  3.27 which I believe is the standard one. However, the data card for my car indicates a different unit serial number than the one currently installed. There were three optional ratios  as well - - correct?
My question is this:   If a sedan power-train is turning  through a roadster differential, is that where the error factor is?  Did the sedans have a numerically higher ratio? Or numerically lower?
Thanks for any help - -  Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: - - more on speedometer issues - -
« Reply #1 on: April 27, 2006, 21:27:40 »
Originally posted by lurtch
The differential ratio is  3.27 which I believe is the standard one......If a sedan power-train is turning  through a roadster differential, is that where the error factor is?
The 3.27 is not a standard W113 ratio.  That's a sedan rear axle.  Do you have rear disk brakes?  Your 230SL should have rear drum brakes (disk in front).
« Last Edit: April 27, 2006, 21:28:02 by rwmastel »
psmith
« Reply #2 on: April 27, 2006, 23:10:47 »
Hi Larry,
My BBB shows the rear axle ratio of 3.75:1 for both auto and stick 230's unless you have a 5 speed 4.08:1!  I think I saw that you were going on the SF Bay Area drive on May 7th, I'll bring my books so you can check out any other info you may need.  I'm waiting to get my CD version so I can see the pictures better.
Pete S.
« Reply #3 on: April 28, 2006, 09:47:25 »
Someone dropper a diff. from a 108/280se-4.5 in there .. probably at the same time they did the M130 engine... good combo.
