Author Topic: Air Filter hose  (Read 3384 times)
Air Filter hose
« on: April 17, 2006, 10:18:49 »
Am I missing a hose clamp on the filter end of the hose? I notice some oily crud on top of canister. If so, do I go MB or any old hose clamp? Also, I have noticed other's hoses much more bunched up. Is that my imagination?
Download Attachment: airfilter.jpg
52.37 KB
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: Air Filter hose
« Reply #1 on: April 17, 2006, 12:26:34 »
Hello from the BayArea  - -  -
YES  you are missing a hose clamp.  The oily crud is there because it has most likely dripped out of that same clampless connection point.  The breather hose that comes over from the valve cover is routing an oil-misty mixture of crankcase vapor back into the engine.    This is a easy fix!   Larry in Menlo Park
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
glcg123
Re: Air Filter hose
« Reply #2 on: April 17, 2006, 13:10:41 »
You may want to look at your air filter element as well as putting on the clamp. Mine was quite gummed up with a mixture of dirt and recirculated vapour from the engine. I replaced it with a MB element and the car has much more power now.
George
Winnipeg Canada
1965 230SL
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Air Filter hose
« Reply #3 on: April 17, 2006, 20:27:44 »
Yes, you are missing a clamp at the air cleaner end, but my hose fits so tightly that I'd be surprised if oil vapor would be enough to cause a leak.
On the 250s and early 280s separate collar was clamped onto the throttle body to provide a warm water coil around the intake.  On the later 280s it was cast in but on the early ones, the collar  substantially shortened the distance between the throttle body and the air cleaner.  It is a royal pain in the rump to put the hose on these models so be glad yours isn't "bunched up"
'68 280SL 4-spd Coupe
Re: Air Filter hose
« Reply #4 on: April 17, 2006, 22:53:25 »
Before my engine was rebuilt, there was always an accumulation of oil sitting in the bottom of the air filter canister and in the creases in the connecting hose. Since the rebuild, the canister and hose seem to stay dry/clean - so the oil in your case may be attributable to a worn engine as well. After all, the oil that leaked out of the hose on your car has nowhere else to go but the bottom of the canister once you put the requisite clamp in place, and it will not do much good there  :evil: !
« Last Edit: April 17, 2006, 22:54:49 by cees klumper »
