Author Topic: Do You Stutter?  (Read 3787 times)
KevinC
Do You Stutter?
« on: February 11, 2006, 12:08:13 »
I have noticed some talk on plug wires in the past but want to get a current consensious. At a stop sign or red light (auto trans in gear, foot on the brake, car not moving) I get a slight "stutter" from the engine. Just for laughs, I pulled into the garage the other night, left the car in gear with the parking brake engaged (yes, I tested this process first; yes, I left the overhead door open part way) to simulate what is happening on the road. With all the lights off and hood open, I had a nice little bluish-white light show going on. No big sparks, just series of short dim ones. I am assuming that a new plug wire set would be in order. What brand/suppliers are suggested? While not a concours car, I do want to eliminate this bothersome problem.
Kevin Caputo
Boca Raton, FL
1967 230 SL Automatic
670 Light Ivory
113 Bronze/Brown MB Tex
Re: Do You Stutter?
« Reply #1 on: February 11, 2006, 18:43:32 »
Gernold Nisius at SL Tech I believe still sells wire sets that are original-spec.
correction: I just checked SL Tech's website and they are now no longer available
If you look through the Technical Articles (ignition) or do a search on this topic, you are bound to come up with a lot of information.
Neat test - must do the same one of these days, although I don't have a stutter ;-)
« Last Edit: February 12, 2006, 01:48:17 by cees klumper »
JPMOSE
  • USA, DE, Harbeson
Re: Do You Stutter?
« Reply #2 on: February 11, 2006, 22:58:15 »
Kevin....you car should run BETTER than the average Concours car as most of them JUST SIT.  Bosch is what I have on my car -- was just tuned professionally -- idles perfect.  I believe that Bosch is OEM.
Best Regards,
J. P. Mose
1968 250SL
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
Re: Do You Stutter?
« Reply #3 on: February 12, 2006, 05:42:56 »
Dr Benz has 'Beru' copper sets that are good.
« Last Edit: February 12, 2006, 05:43:32 by naj »
Re: Do You Stutter?
« Reply #4 on: February 12, 2006, 10:42:48 »
Mine are Bosch. Copper-core. 7mm. Ultra-something. Seem to work very well.
Re: Do You Stutter?
« Reply #5 on: February 12, 2006, 11:22:23 »
You can buy Beru  copper core in correct diam. by the foot at NAPA stores and make your own..
