Author Topic: wiring /harness drawings  (Read 7911 times)
aeneasm
« on: January 15, 2006, 10:48:13 »
1970 280sl autobox,aircon,std dist,rev light. lhd 1st reg USA 1971 chassis no 113044 12 022232. need complete wiring diagram's,harness layout ,wire colours.,for engine,bodywork,autobox. present problem constant speed sol not wired,kick down not working wiring messed up.willpick tab for any expenses.
aeneas
Re: wiring /harness drawings
« Reply #1 on: January 15, 2006, 19:37:29 »
Perhaps you can obtain a wiring diagram by buying a manual mentioned in one of these threads, or by receiving a file directly from another member.
http://index.php?topic=3769+diagram
http://index.php?topic=3465+diagram
http://index.php?topic=1805+diagram
Here are some good publications for the W113:
http://www.sl113.org/publications.asp
Chad
« Reply #2 on: January 15, 2006, 20:08:17 »
Is this provided in the Owner's Manual for the 280? It seems to be in the original one for 230.
« Reply #3 on: January 15, 2006, 22:58:04 »
Hello Aeneas,
USA cars as of about 1969 did not have the constant speed solenoid wired unless the car had Air Conditioning. In fact no wires were run to it at all. Prior to 1969 cars with automatic transmissions had the solenoid wired and working.
As far as the kick down, make sure that the fuses are good, make sure the three position solenoid or its linkage are not stuck, test the kickdown switch under the gas pedal also make sure its plug connection is not corroded.
aeneasm
« Reply #4 on: January 16, 2006, 14:03:34 »
ja17    u could be correct. i have looked all over engine bay and cannot find any loose or cut wiring. car has air-con. the sol is in position.  so what keeps engine at no stall speed when stationery with air con operating.There must be a wiring diagram for the autubox. is'nt a sol that is operated by the kick down. cannot see a sol in my drawings. thanks for help.
aeneas
aeneas
aeneasm
« Reply #5 on: January 16, 2006, 14:50:34 »
The 250/280 sl owners manual I have does not show as it does not even have autobox. this is a new manual I just bought. I did get a drawing from MB Germany and it shows solenoid wired to autobox connections but it does not give in which harness ,numbers,colours. see jb above I think he could be correct. Its is amazing that one can't get a complete set of all elect drawing inc all mods,numbers,wire colours harnesse's.
aeneas
(Moderator's Note:  Edited to seperate quote from reply.)
« Last Edit: January 16, 2006, 21:26:42 by rwmastel »
« Reply #6 on: January 17, 2006, 14:54:11 »
Aeneas - Achim Ahlert (member here) made up a color-coded diagram for the 280 SL himself that is more comprehensive than what can be found in manuals. If you email me your address, I will be glad to send you a (color) photocopy.
« Reply #7 on: January 17, 2006, 18:56:14 »
This can be done by clicking on the username to the left side of the message and then sending the user an e-mail.
« Reply #8 on: January 17, 2006, 20:09:41 »
Rodd and Cees,
Is it possible for this wiring diagram to be hosted somewhere on this site?  I think it would be a valuable resource for anyone trouble shooting electrical problems.
« Reply #9 on: January 18, 2006, 16:42:24 »
I suppose this could be done, I will (assuming it's OK with Achim) see about scanning it and offering it to the webmeisters who can post larger files.
« Reply #10 on: January 18, 2006, 21:06:01 »
Thanks Cees.
