Author Topic: Braking Dust  (Read 3610 times)
ZwoachtzigSL
Braking Dust
« on: December 22, 2005, 00:51:50 »
Hello FRiends.
Some times ago I have seen on US-Internet an installation cap against braking dust on the tires. Where, I have forgotten.
This cap is put together under the rims.
Can you give me a Link where I can have a look at this cap and order?
Detlef, Bad Homburg (Germany)
Stern-Garage
Re: Braking Dust
« Reply #2 on: December 22, 2005, 12:58:10 »
Hello Detlef,
I think you are referring to the "Kleen-Wheels" these are thin aluminum shields with small directional vents punched into them and painted heat resistant black paint.  These are beneficial for the aluminum 'bundt-cake' wheels.
But be warned these also can cause brakes to overheat if used in heavy braking and thus warping the rotors.
Walter Klatt
1967 220SL-diesel
1963 230SL-gas
« Last Edit: December 22, 2005, 12:59:03 by waltklatt »
RBurg
Re: Braking Dust
« Reply #3 on: December 22, 2005, 17:04:26 »
MB does not recommend the use of a brake shield - they build up too much heat. I have a set of 16" on the E430 - remove the shields and notice improve braking.
Ron
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
