Author Topic: My Firewall Pad  (Read 7202 times)
George Des
My Firewall Pad
« on: December 14, 2005, 20:04:05 »
Been much talk about the firewall pads and the different "textures". The attached photo shows the factory original firewall pad on my 1967 230SL Euro ZF 5 Speed as it was delivered in Nov 1967 to an Italian physician from Rovigo, Italy. (I still have all the original documentation, bill of sale and Italian registration material.) I purchased in 1976 while in Vicenza, Italy. This photo was taken in 1981 while I was stationed at Camp Darby (Livorno), Italy outside of Pisa. The pad has long since been changed out for one of the newer style pads offered by all the usual suppliers and is noticeably different in both thickness and texture.
George Des
Download Attachment: firewallpad1.jpg
34.17 KB
Re: My Firewall Pad
« Reply #1 on: December 14, 2005, 20:31:04 »
Here's the only 230 SL I've ever seen with what appears to be an original firewall pad in decent shape:
http://motoringinvestments.com/C87photo3.htm
Perhaps it was updated at some point when the OEM part was still available.
« Last Edit: December 14, 2005, 20:31:37 by Douglas »
Re: My Firewall Pad
« Reply #2 on: December 14, 2005, 21:23:17 »
Originally posted by Douglas
Here's the only 230 SL I've ever seen with what appears to be an original firewall pad in decent shape: ...
Not only does it have the original firewall pad, this is the 1st time that I have actually seen a cover over the large fuel pump - but then I am a Newbie (or greenhorn if you prefer) to these cars. And I am awed by these fire-red trumpet horns in the engine bay  :)
Tom230sl
Re: My Firewall Pad
« Reply #3 on: December 14, 2005, 22:50:09 »
early style pad pattern.  Was made of a rubber slurry over the fiber insulation material.  This caused the rather undefined pattern.  Later style is made with a machine pattern.
Download Attachment: earlya.jpg
78.6 KB
Download Attachment: earlyb.jpg
69.05 KB
Tom230sl
Re: My Firewall Pad
« Reply #4 on: December 14, 2005, 22:55:25 »
does not seem to have body color(red) under pad??  or anywhere in engine compartment. Not a good example.
« Last Edit: December 14, 2005, 23:02:04 by Tom230sl »
Re: My Firewall Pad
« Reply #5 on: December 15, 2005, 02:53:05 »
..........I agree, this car has clearly been painted by someone who is NOT familiar with the factory look, even the bonnet spring has been careful !
.........I dont see any cover, are you looking atv the fluid resevoir ?
Re: My Firewall Pad
« Reply #6 on: December 15, 2005, 06:14:35 »
Originally posted by Tom230sl
Quote
Tom,
I was merely calling attention to the OEM pad, not the car. Obviously, the car went through a color change.
Mahopac, NY
Re: My Firewall Pad
« Reply #7 on: December 15, 2005, 06:49:14 »
If you open up the link Doug listed, and scroll down, there are a number of good undercarriage photos. They also show the smaller fuel tank discussed a bit in another post about 230SL on ebay.
Tom230sl
Re: My Firewall Pad
« Reply #8 on: December 16, 2005, 14:25:30 »
Hey Douglas, I understand.  I guess my point was that its probably more likely that the engine  compartment was sprayed black  since under the hood was also.  And the firewall  being black., someone probably replaced the pad at some point  so it may not be the original to the cars build date.
Re: My Firewall Pad
« Reply #9 on: December 20, 2005, 20:54:32 »
Originally posted by Ben
Quote
Hi Ben, I am not sure what I am looking at but it sure looks like a pump cover. Take  a look:
Download Attachment: PumpCover.jpg
30.26 KB
Re: My Firewall Pad
« Reply #10 on: December 21, 2005, 03:01:12 »
30.26 KB
OOOOpps !   Yeah I see it now, it IS a pump cover, I was looking at a different photo !
I believe they should have that, mine doesn't either !
Re: My Firewall Pad
« Reply #11 on: December 21, 2005, 11:34:56 »
Here is a pic of my car with the original firewall pad in good shape
Download Attachment: MyEngine.JPG
45.62 KB
113gray
Re: My Firewall Pad
« Reply #12 on: December 23, 2005, 18:33:01 »
Quote
Firewall pad looks great; not as sure about the horn trio [:0]  -JP-
JPMOSE
  • USA, DE, Harbeson
Re: My Firewall Pad
« Reply #13 on: February 16, 2008, 08:40:21 »
George,
Could you repost the photo of your original firewall pad?  It doesn't open to a photo anymore.   Thanks!
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
