Author Topic: Here is what I have with and without a sub harness  (Read 35 times)
CJHenderson
  • USA, AR, Benton
 With the sub harness I have everything according to the instructions on testing the column switch table minus the turn signal light actual operation, most likely bad flasher relay unit. Removing the sub harness I have lost everything but gained the high beam when pulling the lever switch which is redundant due to having the mechanical light switch on the firewall again following the testing of the column switches.
 One other thing I used the old flasher which had no effect with the sub harness and when I used it without the sub harness it melted the #5 fuse it didn't blow the fuse it actually melted the fuse.
1950 MG-TD
