Please check out joining the
Emergency Contact List
for help during your travels!
which head gasket is the right fit?
Topic: which head gasket is the right fit? (Read 187 times)
Artkez
Full Member
Regular
USA, CA, Los Angeles
October 17, 2025, 05:33:44 »
my engine has been swapped with a 1969 280SE engine, so it is a m130 980 engine (the whole engine number is 130 980 13 016620) and it says 280SE/A on the side if that helps
which head gasket should i purchase for a replacement? I just want to give the right parts to my mechanic to make things move smoothly
seems like there are some with a more square shape, and one with a more angled pointy shape, and some made by victor reinz, and some made by elring?
https://www.ebay.com/itm/226841612906
https://www.ebay.com/itm/353802661268
https://www.ebay.com/itm/197482275901
https://www.authenticclassics.com/Head-Gasket-Set-fits-Mercedes-280SE-280SL-300SEL-p/auth-009665.htm
this seems like the one based on the description?
over this
https://www.authenticclassics.com/Head-Gasket-Seal-Set-fits-Mercedes-280SE-280SL-300-p/auth-009664.htm
BobH
Full Member
Platinum
United Kingdom, England, MALDON
Re: which head gasket is the right fit?
October 20, 2025, 17:12:25 »
Hello, if you still haven't ordered a new gasket yet, have a look on here
https://www.sl113.org/forums/index.php?topic=15041.0
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
