Author Topic: Door latch step  (Read 129 times)
Door latch step
« on: October 09, 2025, 19:22:08 »
Are door latches designed to be strong against tensile or shear forces?  Scroll way down on the website until you find the video.  It's a great idea, if the car part is designed for that type of force.
https://ancestraloutdoors.com/collections/main-products/products/easyroof
Re: Door latch step
« Reply #1 on: Today at 11:53:09 »
OMG. You first!
I have a better idea. It’s called a ladder or stepstool.
I can easily see something like that eventually deforming the piece it hooks onto, depending on the weight of the person using it.
Then one will wonder why their door never closes properly any longer…
Re: Door latch step
« Reply #2 on: Today at 15:11:25 »
Deforming the loop or catch or whatever it's officially called?  Yes, that's a possibility.  I was more concerned about the possibility of pulling out the screws or rivets or spot welds holding that piece to the door jamb.
The site says 310 lbs weight limit, but that's for their device. What's the limit for the part on the vehicle?  I mean, it's supposed to keep the door closed in an accident, which can be very high forces, but this is stress/force in a different direction.  I don't know.  It's a creative idea, but I don't know if I'd use one.
Re: Door latch step
« Reply #3 on: Today at 16:18:29 »
For a regular car you do not need it. For SUV (not to mention off-road cars) you should be able to step on the tire. In emergency you can pull out floor mat and put it on the door sill.
Why would you even consider using this thing?
kampala
  • USA, CA, Hermosa Beach
Re: Door latch step
« Reply #4 on: Today at 18:25:26 »
This type of product was on Shark Tank (investment show) many years ago.
https://youtu.be/cMYX4FfMT1A?si=jLCSZQa1CsLR-w-w
250sl - later - manual
280sl - 1971 - Auto - LSD
