Author Topic: Verify wheel fit  (Read 386 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Verify wheel fit
« on: October 06, 2025, 19:41:18 »
On a 250se ( high grill)  coupe 1967 I want to go to 14"x 6.5"  bundt ( mexican hat) rims. My question is will stock ones fit? What size tires do I need so not to scrape front or rear fenders. What et should the bundt rims be?
Thanks Bob
« Last Edit: October 07, 2025, 02:10:21 by BaronYoungman »
Bob "Baron" Youngman
1965 220se coupe restomod
SEB
  • Germany, Berlin, Berlin
Re: Verify wheel fit
« Reply #1 on: October 08, 2025, 15:22:25 »
Hi Bob,
I also had a March 1967 250SE high grill coupe in Papyrus White with chrome side trim, so I know these cars well.
14 x 6.5 Bundt (Mexican hat) rims will fit your 250SE  without major issues if you choose the right offset and tire size.
Rims:
Original Bundt wheels for W108/W111 had ET30 offset. This keeps the wheels centered in the fenders.
Tires:
195/70 R14 for closest to original diameter
205/70 R14 for a slightly wider fit that still clears the fenders
Avoid ET25 or lower, as the wheels may rub the front fenders when turning.
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
