Bosch WDC7 or NGK BP5ES plugs are my recommendation. And copper core plug wires.
Discussion of plug wires and resistance is frequent. A little research will yield the following:
1. It doesn't matter WHERE from point A (distributor) to point B (plugs) the resistance is; it's the total resistance between these points that matters.
2. Our cars were initially specified with copper core wires (~zero ohms resistance) and Beru or Bosch resistor plug connectors (1K ohms).
Now, if you look at some of these facts you'll see why the issues of "use copper core" and "non-resistor plugs" comes up.
1. The resistance in an NGK resistor plug is ~5K ohms.
2. The resistance in carbon core wire varies greatly, but can be 3K-7K ohms PER FOOT.
So, if you use the inappropriate resistor plug, combined with the inappropriate carbon core wire, #6 cylinder may have over 10K ohms resistance.
The resistance in the ignition circuit is basically there for RFI/EMI Suppression. The resistance partially attenuates high-frequency RFI generated by the spark. This prevents interference with your radio, engine computer, and other onboard electronics. Since only the later Pagodas had any electronics the effect would be mostly on AM radio. Resistance also helps limit peak current and extends the duration of your spark. I guess a longer spark means better combustion?
FWIW in 2011 or so, I removed the Crane XR700 capacitive-discharge ignition system, and replaced it with the Pertronix Ignitor 1864LA. I had a custom wire set made with Beru copper core wire, and Beru 1K shielded connectors. I used their black Flamethrower II coil. Everything went in smoothly save for a little file-work on the Ignitor unit to sit properly on the base plate of the -051 distributor. Once that was in, and the engine timed, it has been essentially untouched now for close to 15 years. Yes the current instructions on Pertronix call for suppression wire but I do not believe my instructions from 15 years ago said that. It's possible that they had some failures of the sensor assembly due to extreme RFI/EMI. But in 15 years of solid and more importantly, consistent operation I think I'm OK.
